NTSB releases probable cause for Steve Fossett crash
Old July 10th 09, 05:44 PM posted to rec.aviation.piloting
John Clear
Default NTSB releases probable cause for Steve Fossett crash
Gezellig wrote:
On Thu, 09 Jul 2009 17:44:28 -0500, Jim Logajan wrote:
http://www.ntsb.gov/ntsb/brief.asp?e...07X17184&key=1
How long after first impact should it take for the ELT to kick out a
call on frequency?
If the ELT isn't destroyed in the crash, it usually doesn't go off until
the wreckage is hauled away.
406 ELTs are slightly better then 121.5 ELTs in terms of false
positives (ELT goes off with no crash), but in real crashes, they
both have extremely high failure rates.
I don't have access to the stats any more, but when I was in CAP,
something like 98% of ELT searches where false activations, and
ELTs failed to activate in about 95% of all crashes. Numbers are
from memory, so might be off by a bit, but the magnitude of the issue
should be obvious.
Being on flight following and/or getting off a Mayday before crashing
greatly increase your chances of being found. Manually triggering
your ELT before impact might help, if it survives the impact.
John
John Clear - http://www.clear-prop.org/
Old July 10th 09, 06:34 PM posted to rec.aviation.piloting
spanky
On Jul 10, 6:48*am, Gezellig wrote:
CAP was combing the area by the NTSB with no report of transmission so I
suppose we can extrapolate that a severe enough impact can render the
ELT useless. I am guessing where the AC took the initial hit would be
important too in relation ot the positioning of the ELT in the AC.- Hide quoted text -
- Show quoted text -
....i think we can infer from the following description of damage, from
the information found on the NTSB Summary's "Full Narrative" link,
that listening for an ELT signal, regardless of where it was installed
in the aircraft, was moot:
"The airplane was severely fragmented and a severe post crash fire
burned most of the structure and surrounding vegetation. The first
evidence of ground contact was a boulder with paint transfers on it
consistent with the left main wheel and the belly of the airplane. "
"All of the cockpit instruments and avionics were destroyed. Pieces of
instruments were found scattered throughout the debris field. The
airplane's ELT was destroyed; numerous pieces of its orange plastic
case and internal circuit board components were found scattered in the
debris field."
....and this:
"The engine sustained severe impact damage. The crankshaft was broken
off about 3.5 inches inside the nose case, a piece of the nose case
was broken out, and the front thrust bearing was partially extruded,
bent and deformed. All accessories and the oil sump were stripped from
the engine. The cylinder heads of the right side cylinders (#1 and #3)
were destroyed; the impact crush angle measured at the lower #1
cylinder barrel was 39 degrees."
....and finally:
"The front seat frame was bent, deformed and crushed to a size about
one third of its original dimension."
S McF
Old July 10th 09, 06:54 PM posted to rec.aviation.piloting
gpsman
On Jul 9, 10:14*pm, Mike Ash wrote:
If it can happen to him,
it could happen to you!
And that's the most important thing this low hours pilot takes from
every crash report.
I'm not afraid to die, I just don't want to bend a perfectly good
airplane in the process.
As this relates to trucking, an area where I have more expertise, it
is often the most experienced drivers who are involved in the most
serious incidents.
- gpsman
Old July 10th 09, 10:52 PM posted to rec.aviation.piloting
Gezellig
call on frequency?
Tell me about it. Mine went off on a maintenance tow
should be obvious.
Holy s**t, I never knew, now I feel better.
John
Thx.
Old July 11th 09, 03:37 PM posted to rec.aviation.piloting
Peter Dohm
"Gezellig" wrote in message
call on frequency?
should be obvious.
John
Thx.
This seems to really involve more than one subject:
1) In the particular case of Steve Fossett; it appears that timely
location would have made no difference at all for Mr Fossett, but admittedly
would have saved a tremendous amount of effort and also expedited and
simplified the settlement of his estate. (As a side note, simply as
serendipity, the search for Mr Fossett did appear to uncover the answers to
some other misteries which had been under investigation for some time.)
2) One of the major arguments for the adoption of the 406Mhz system was
the ever expanding use of the 121.5Mhz beacons by hikers, boaters, and
probably others as well. IIRC, the new beacons were supposed to be
available for the various uses so that searchers would have greater reason
to presume which type of incident might be involved. (I have not ket up,
and don't know whether the change has helped; but there do seem to be some
similarities to the use of other emergency response systems.)
3) When I was working on avionics, it seemed to me that about three
fourths of all radio problems that I saw were airframe wiring as opposed to
inside the radios. The radios themselves have probably gotten more reliable
in the years since, so I would be amazed if the change to 406Mhz has made
much more difference in physical reliability than would have been the case
if all of the old 121.5Mhz beacons were completely removed and then
completely reinstalled during the same time period.
4) In the event that most false or inadvertant activations actually occur
on airports, which would certainly make sense, then there should be a fairly
simple and cost effective method to observe, locate and deactivate the
beacons in question.
5) Crashes that occur away from the airports, where a search operation is
needed, probably involve a very small percentage of pilots and passengers
over their lifetimes. I really don't know how small that percentage is; but
if the percentage is as small as I suspect, then there is some question
about whether any system makes sense--with the exception of post crash
beacons in aircraft carrying passengers commercially and possibly combat
aircraft. (If the lifetime probability, for the participants in the
activity, is only one or two percent, then it is long past time to reopen
the debate about general aviation fleetwide use in terms of its value versus
cost in money, time, effort, freedom and privacy.)
Peter
Old July 12th 09, 06:34 AM posted to rec.aviation.piloting
John Clear
406Mhz ELT/EPIRB/PRB emit a distinct identifier and are supposed
to be registered, so false positives can often be taken care of
with a phone call and not a SAR team going out at 2am looking for
it.
Most false activations are on airports (or marinas, EPIRBs are on
121.5/406 as well). Tracking down which specific plane/boat is
still very time consuming with 121.5 beacons. With 406 beacons,
it is much easier, if they are registered. Especially at airports,
the metal hangars make finding the activated 121.5 beacon very
challenging since the signal reflects all over the place.
Another unfun one to track is when someone sends a ELT/EBIRP in for
servicing, but doesn't remove the batteries. UPS trucks have
plastic tops, so the signal hits the satellite just fine, but
tracking the moving target from the ground is nearly impossible.
ELTs were originally mandated by Congress after Congressman Hale
Boggs's plane went missing in 1972 (and still hasn't been found).
There never was a serious discussion of the cost/benefits of ELTs.
http://en.wikipedia.org/wiki/Hale_Bo...nce_and_search
I haven't seen any stats, but I feel the number of survivable
crashes where an ELT assisted in the rescue is very small. On the
water, a large number of rescues have been the result of EPIRB
activations. I've heard ELTs referred to as ballast, since the
most useful thing they do is move the CG aft.
John
Old July 12th 09, 02:27 PM posted to rec.aviation.piloting
Gezellig
Peter
I was told but never confirmed that it was a prerequisite for insuring
the plane and, potentially, the pilot.
Old July 12th 09, 02:30 PM posted to rec.aviation.piloting
Gezellig
Do you know if there is a mandated position on any plane where the ELT
must be installed? Or is it mfg preference (so to properly balance CG,
etc)
Old July 12th 09, 06:32 PM posted to rec.aviation.piloting
Ron Wanttaja[_2_]
I flew a plane for seven-eight years without an ELT, and the insurance
carrier never seemed to care. That was just a liability policy, though.
Steve Fossett Steve Piloting 32 December 8th 08 03:19 PM
Steve Fossett bumper Soaring 10 December 5th 08 08:11 AM
Steve Fossett NoneYa Piloting 32 September 11th 07 03:45 AM
Steve Fossett Brian Milner Soaring 3 September 8th 07 09:26 AM
Steve Fossett [email protected] Owning 15 September 7th 07 09:45 PM
