Oudie with a LX 5000
Old May 21st 10, 08:53 PM posted to rec.aviation.soaring
Randy[_2_]
Default Oudie with a LX 5000
I have a question about hooking up the Oudie to my LX 5000.
When I was using my IPAQ the serial port from my IPAQ is
a female plug. On the Oudie, it is a male serial plug. Is there
another option about hooking this up with a LX 5000?
Is anyone using the Oudie with a LX 5000?
Thanks for your time.
Randy
http://talihinasoaring.com/
Old May 21st 10, 09:27 PM posted to rec.aviation.soaring
Paul Remde
Hi Randy,
The pin connections are not compatible. The Oudie's cable is setup for use
with a Cambridge GPS-NAV or 302 - not an LX product. The Goddard PXF-0.5
cable would be the perfect adapter cable.
http://www.cumulus-soaring.com/goddard.htm#PXF-0.5
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Randy" wrote in message
Randy
Old May 24th 10, 11:48 AM posted to rec.aviation.soaring
Andrej Kolar[_3_]
A null-modem cable with female/female connectors or the standard
serial cable from LX 5000 with binder connector will also do the
trick.
The pinout on the Oudie connector is exactly the same as the standard
RS-232 pinout with 2=Receive to Oudie, 3=Transmit from Oudie,
5=Ground.
Regards,
Andrej Kolar
On 21 maj, 21:27, "Paul Remde" wrote:
Hi Randy,
The pin connections are not compatible. *The Oudie's cable is setup for use
with a Cambridge GPS-NAV or 302 - not an LX product. * The Goddard PXF-0.5
Best Regards,
Paul Remde
When I was using my IPAQ *the serial port from my IPAQ is
Randy
New Oudie Photos Paul Remde Soaring 3 April 30th 10 05:17 PM
Naviter Oudie Units Shipping Soon Paul Remde Soaring 5 April 7th 10 03:05 PM
Naviter Oudie Should be Available in April 2010 Richard[_9_] Soaring 15 February 6th 10 11:40 PM
FS: LX-5000 FAI v. 11 Greg Arnold Soaring 0 January 8th 05 02:18 AM
