Video of Powerflarm brick in action
Old August 30th 12, 08:30 AM posted to rec.aviation.soaring
Ramy
Default Video of Powerflarm brick in action
Courtesy of Peter Kelly. The action starts at 2:00
http://www.youtube.com/watch?v=hwj6DA8OITU
Ramy
Old August 30th 12, 11:11 AM posted to rec.aviation.soaring
have you demo like this on lift with no 30, but ~10 gliders? flarm is good sometimes very good, but save feeling cause dangerous ...
Old August 30th 12, 01:50 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
On Aug 30, 2:30*am, Ramy wrote:
Courtesy of Peter Kelly. The action starts at 2:00http://www.youtube.com/watch?v=hwj6DA8OITU
Ramy
I curious about his antenna placement. Is PK non-carbon?
QT
Old August 31st 12, 02:56 AM posted to rec.aviation.soaring
Ramy
Ramy
QT
PK is an ASH 26E with a PowerFlarm Brick installed. The nose of the ASH 26 is glass and aramid fiber. The Flarm A and ADS-b di-pole antennas are attached to the fuselage skin in the nose near the rudder pedals with Velcro.
Clean easy install. Seems to have good reception.
Rex
Will this installation work in a 27? I know that the cockpit area below the seat pan is glass since that's where my transponder antenna is, so wonder if there are other suitable places to put the flarm antenna.
Ramy
Old August 31st 12, 03:39 AM posted to rec.aviation.soaring
son_of_flubber
Once you install Flarm, are you tempted to fly in formation more often than you did before you installed it?
More generally, how does Flarm change your flying habits and margins?
How did Flarm change flying habits in Europe (or any country that has had Flarm for a some years)?
Old August 31st 12, 05:26 AM posted to rec.aviation.soaring
Ramy
If anything it causes me to keep more distance knowing that otherwise both the other pilot and myself will keep receiving alarms.
Ramy
Old August 31st 12, 09:11 PM posted to rec.aviation.soaring
K
Ramy
Ive used a PF portable on a mounting tray that I purchased from Williams Soaring. I am very impressed so far not just the way this picks up glider traffic but the big stuff as well. I was flying a contest at Air Sailing NV and twice while KRNO was landing south there were airliners turning base over Air Sailing. Both times the PF detected these airliners while they were 8 and 16 miles away.
My home field lies under the Class B at KSLC and I am constantly amazed that the PF picks up all the airline traffic. Some of which before it is acquired visually. At a 300KT closure rate this is important! FWIW I use TCAS at work and I really like the PowerFlarm unit and I hope the technology continues to evolve.
Now when are we going to have Logger approval?
Old September 1st 12, 01:51 AM posted to rec.aviation.soaring
Ramy
Ramy
Are you referring to mode C/S or ADS-B? If the later, how did you identify those as ADS-B vs other flarms? So far I can't tell the difference, or perhaps I didnt receive an ADS-B alert yet which will be odd since I fly in the Reno area.
Ramy
Powerflarm Brick feedback Ramy Soaring 7 August 10th 12 02:02 AM
Measured current draw, PowerFlarm Brick Evan Ludeman[_4_] Soaring 4 July 16th 12 01:03 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
PowerFLARM 'brick' progress? Frank Paynter[_2_] Soaring 5 November 13th 11 08:28 PM
Display for PowerFLARM brick Andy[_1_] Soaring 4 May 10th 11 03:32 PM
