Google Glass in the cockpit?
Old May 27th 13, 04:07 PM posted to rec.aviation.soaring
Bill D
Default Google Glass in the cockpit?
On Sunday, May 26, 2013 11:15:44 PM UTC-6, Darryl Ramm wrote:
Yep so much for dreaming. From some brief playing and knowing several developers playing with these...
The glass display is quite difficult to read in full-daylight. It often works well in a car if you have a roof over your head. In bright direct sunlight it is very washed out.
Battery life can be very limited, very dependent on application/usage. You'd need a power connection or external battery pack for long flights.
The display is far from immersive. It's a small display in the top of your viewing area. See the simulation in the Google promo video here http://www.youtube.com/watch?v=v1uyQZNg2vE So kind of big enough to display basic info, not too big to be ultra distracting.
What is interesting is for many different uses how Google and others have condensed information into such as small display and made it very useful.
What could you display for a glider? Vario, STF, L/D required, distance/direction to a turnpoint, (in PDA/PNA parlance you'd probably only display one two or three "nav boxes" of data) look up frequencies for an airport/ATC etc. simple stuff like that.
As pointed others have pointed out without head tracking things like direction to... type information is not that interesting. With head tracking, better daylight visibility (and maybe a larger display) you might potentially be able to do much more interesting things like direction/distance to a collision threat/buddy/turnpoint/airport etc.
Swiping the side of the glass' trackpad sometimes is annoying, requires a few tries. I think its a much worse UI device in a cramped cockpit than buttons/switches/trackball on a joystick.
Voice commands could be interesting but I'd like to see them integrated into the flight computer. Maybe as a thin UI layer to a flight computer/PDA/PNA glass could provide that, but it may be a lot of hassle to go though just to get that. You might as well run that on more modern PNA/PDAs.
So all in all, I think there really is not something here to excited about, at least for quite a while. There are many more practical/interesting real-world applications for glass.
Darryl
Agreed. It's not yet clear what, if any, role Google Glass has in the consumer space much less what it might be adapted to in gliders.
However, it's worth thinking about what more advanced devices might do for us in the future. What I think we want is a true Augmented Reality device which overlay's our visual field with tightly registered and highly pertinent data. That means data about an airport off the left wing wouldn't be visible until we looked at the airport. Voice commands, or stick switches, could further limit and control the data displayed. One switch might display navigation data - where are airports? Airspace? Another switch might display soaring data - Cloudbase? Likely thermal sites? Blipmaps?
A more futuristic aspect ties back to another thread on attitude displays. If VR technology can display a perfect POV replica of the real world, including air traffic, would there be any real difference between flight in VMC and IMC? And, if that distinction goes away, will contest rules have to change?
OTOH, I don't necessarily disagree with the anti-tech crowd. It might be fun to have a low performance contest where no instruments beyond those on the glider's MEL are allowed.
Google Glass news of interest to pilots and soaring app developers son_of_flubber Soaring 14 February 23rd 13 06:41 AM
Glass Cockpit Architecture Douglas Eagleson Home Built 0 September 14th 10 07:14 PM
Glass cockpit hard to read Arno Piloting 83 October 9th 07 07:41 AM
Why Not Use PC To Make Glass Cockpit? Le Chaud Lapin Instrument Flight Rules 52 July 19th 05 04:45 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 02:20 AM
