ASG29 Panel (small) layout ideas for ClearNav II installation
Old December 23rd 15, 07:36 PM posted to rec.aviation.soaring
JS
Default ASG29 Panel (small) layout ideas for ClearNav II installation
There are some different instruments available on various AS model panel layouts on their website. The ASG32 has Butterfly vario and Trig TXP (but round install, you need to crop).
None of them have ClearNav display or Vario displays. I'm laying out a normal sized ASG29 panel with no 80mm instruments, pretty easy. The ASW28 (Small ASG29 panel) is tricky.
Sean, I might be installing my CN2 in the new panel without the tunnel mount, so that mount (with CN2 speaker mounted in the top of the tunnel) would be available. In a small panel you gain precious space if you mount shallow instruments next to the tunnel.
As far as I'm concerned, nothing goes on top of a glare shield and nothing hangs off the panel like some afterthought. Did violate that with one of Craggy's #500107 FLARM antennas.
Old December 24th 15, 07:04 AM posted to rec.aviation.soaring
Sean Fidler
thx Jim.
Cad drawing for ASW27 or ASG29 instrument panel Larry Goddard Soaring 16 December 30th 18 08:19 PM
How to determine if your ASG29 has the large or small panel? Sean Fidler Soaring 37 November 19th 14 07:50 PM
panel fastening ideas [email protected] Home Built 6 May 20th 08 08:21 PM
Is there a "correct" panel layout? Dico Owning 8 May 25th 06 02:47 AM
Shop Layout Questions GreenPilot Home Built 37 July 6th 04 03:47 PM
