PA28 140 starter removal
Old October 30th 04, 06:38 PM
George Hamilton
Default PA28 140 starter removal
Can someone tell me if I can remove the starter from 0 320 Lyc without
taking the prop off. Starter is old an has been acting up for some
time. Needs new brushes for certain.
Old October 30th 04, 11:21 PM
Jay Masino
Yes, the only caviat being that, if you have a one piece nose bowl, it's
a little tight to work up there, but you can do it.
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old October 31st 04, 06:07 PM
George Hamilton
I did the job this morning. It took two hours to get the starter out.
You must remove the prop, front of cowl and unbolt the oil cooler to
get at the four 1/2 inch nuts holding it on. Not a bad job but a
little tight.
Starter Questions Aaron Coolidge Owning 4 June 30th 04 03:52 PM
Stuck starter solenoid? Paul Lee Home Built 4 April 16th 04 03:58 PM
LIghtweight starter recommendations for PA24-250? Chris Kennedy Owning 4 April 8th 04 01:01 AM
Starter selection -- seeking input [email protected] Owning 3 April 5th 04 01:43 AM
Sticking Starter Wayne Owning 5 September 2nd 03 08:26 PM
