Okay, silly(?) question time:
I have a 1964 Cessna 182 (12v), how do you jump start it if the battery dies, or should I even attempt it? Thanks for any advice! Jeffrey |
There's two ways. First look and see if there is a ground service plug.
Mine on my 67 182 is pilots side just forward of the door. If you don't have the right jumper cables for that plug just use any old jumper cables and connect right to the battery like in your car. First however put a charger on the battery for a half hour or so. If your battery is low enough the alternator won't charge it because an alternator needs to see a little voltage in the battery before it will even turn itself on. A few years ago I had a short that caused my master to turn on when it got wet due to a leak. The T+B gyro ran for 13 hours until the battery completely died. I flipped the master next time and nothing, dead silence. I got the lineboy to jumpstart the plane. Somehow when I turned the avionics master on the radios came on. Then I flew for three hours and landed for gas. When I turned the master on, nothing. Jumpstarted it and tried to turn the radios on and nothing, just dead. This time I put a battery charger on for 30 minutes and then jumpstarted the plane again. This time the radios came on and after the 2+ hour flight the battery was charged. Jeffrey wrote: Okay, silly(?) question time: I have a 1964 Cessna 182 (12v), how do you jump start it if the battery dies, or should I even attempt it? Thanks for any advice! Jeffrey |
Jeffrey wrote: Okay, silly(?) question time: I have a 1964 Cessna 182 (12v), how do you jump start it if the battery dies, or should I even attempt it? I used to have to jump my '59 172 every now and then. I just jumped it the same way as a car. Open the cowl, attach the jumper cables to the plane's battery, crank the engine, remove the jumper cables. All of the standard cautions about being near a spinning prop apply. If your battery is completely dead (i.e. left the master on all night) and your plane is equipped with an alternator instead of a generator, you can jump start the engine, but your battery won't start charging unless you leave the jumper cables attached for awhile after the engine starts. Alternators require the battery to supply a small bit of current to power the primary field. Caveat : Dead batteries do not take well to having a massive charge delivered all at once, which is what will happen if you try to let the alternator do the charging. If the battery is totally flat, your best bet would be to remove it and put it on a battery charger. John Galban=====N4BQ (PA28-180) John Galban=====N4BQ (PA28-180) |
| Thread Tools | |
| Display Modes | |
| Turbine air start -- too cold? | Juan Jimenez | Home Built | 97 | March 14th 05 07:51 PM |
| Turbine air start -- too cold? | Juan Jimenez | General Aviation | 54 | February 2nd 05 05:14 AM |
| Start receiving MONEY with this simple system. Guaranteed. | Mr Anderson | Aviation Marketplace | 0 | February 3rd 04 12:55 AM |
| Military to Start Court Martial of Air Force Translator | Otis Willie | Military Aviation | 0 | January 13th 04 09:47 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
