Cobra trailer wing dolly plastic sidewall rollers?
Old April 28th 13, 08:08 PM posted to rec.aviation.soaring
Default Cobra trailer wing dolly plastic sidewall rollers?
When I was at the Perry contest last week, another pilot mentioned to me that the wing dolly plastic rollers that run in side channels to keep the dolly upright had worn out, causing his wing dollies to bind when rolling in/out of the trailer. We looked at mine, and they are badly worn as well, so I'd like to get replacements.
Does anyone happen to know the dimensions and material for these items? I'd rather get the parts from McMaster-Carr if available, as I suspect I could get them much cheaper/faster than all the way from the factory.
TIA,
Frank
Old May 2nd 13, 06:18 PM posted to rec.aviation.soaring
TIA,
Frank
I wound up getting Delrin rod stock from McMaster-Carr and fabricating my own replacement rollers - worked great! ;-). If anyone is interested in replacements for their own Cobra trailer, let me know.
Old May 9th 13, 05:31 PM
Gyorgy Gulyas Gyorgy Gulyas is offline
Junior Member
First recorded activity by AviationBanter: Oct 2012
TIA,
Frank
I have the same issue and looking for replacements. Do you have some available?
Thank you, Gyorgy
Old May 9th 13, 11:45 PM posted to rec.aviation.soaring
Jim[_31_]
TIA,
Frank
Did you consider Rollerblade wheels? They *look* about the same.
-Jim
Old May 9th 13, 11:52 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Thursday, May 9, 2013 4:45:42 PM UTC-5, Jim wrote:
Did you consider Rollerblade wheels? They *look* about the same. -Jim
I made some for the Cobra trailer I am working on. Just got some 3/4 inch diameter nylon bar, cut off a quarter inch thick slice, drill a hole in the middle for the bolt, and install. Of course, it works much easier when you can remove the parts from the sidewall first...
Asw20 fusalage dolly wanted for cobra trailer Gregg Leslie[_2_] Soaring 2 January 14th 13 04:22 AM
plastic or metal fenders on the trailer? chris Soaring 14 December 20th 10 10:51 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 03:11 AM
Minden Trailer Dolly Wheels gfoster07k Soaring 3 September 19th 08 06:12 AM
Wanted: Wing Dolly(s) for PIK-20 P.Corbett Soaring 1 March 17th 06 02:11 AM
