FLARM Core weight
Old May 11th 13, 02:27 AM posted to rec.aviation.soaring
Default FLARM Core weight
Anyone happen to know the weight of the PowerFlarm Core unit? It is not listed in the PowerFLARM Version 2.20 manual.
Thanks Stephen
Old May 11th 13, 02:56 AM posted to rec.aviation.soaring
Craig Funston[_2_]
Thanks Stephen
Just weighed mine. Bare unit (no cables, etc.) is 256 grams.
Craig
Old May 11th 13, 03:23 AM posted to rec.aviation.soaring
So 0.564383 pounds. I'm updating W&B.
Thank you Craig.
Craig
Old May 11th 13, 03:19 PM posted to rec.aviation.soaring
Thank you Craig.
Craig
Micha,
Let's join the rest of the civilized world including the scientific community in this country and do our cg calculation in metric units, in our case kg and mm. Until recently, we were the only country in the world besides Burma that still uses imperial measures. Guess what, Burma is converting I heard...
Herb
Old May 11th 13, 03:26 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Sat, 11 May 2013 06:19:41 -0700 (PDT), wrote:
[snip]
....and Liberia.
Old May 11th 13, 04:10 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Thanks Stephen
Mine, with the two standard antennae, cables, GPS, usb through-panel, ram mount for the butterfly rectangular display, is 686 grams.
Old May 11th 13, 08:21 PM posted to rec.aviation.soaring
Hi Herb,
Indeed. I work with metrics all day long in the coffee business. Was just giving something back... The SeeG program works well with either unit. Course it uses Kg and not grams so you need a little math.
Cheers and good lift.
Stephen
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 05:24 PM
WTB Lycoming O-235 Core or ? 172flyer Aviation Marketplace 2 January 29th 06 07:31 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 10:26 PM
Looking For A Lycoming IO-360-C136 Core Clyde Torres Home Built 8 August 28th 04 11:22 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 05:20 AM
