SN10b and Flarm core
Old May 24th 16, 03:26 AM posted to rec.aviation.soaring
AS
Default SN10b and Flarm core
Has anyone out there ever used the Flarm-core's GPS-out signal coming from the 9pin subD plug to pipe it into an SN10b? If so, what kind of a connector did you use?
I just don't want to run yet another GPS-engine if the signal is available already but not used.
Uli
Old May 24th 16, 03:45 PM posted to rec.aviation.soaring
K m
Uli
I looked into this a few years ago. Cannot recall which port I used on the Brick. Nothing available over the counter so I made my own. Paul at Cumulus offered to have his guy make one for me (Don't know if this service is still available). At current prices it harness will cost more than the SN10 is worth.
Old May 24th 16, 04:11 PM posted to rec.aviation.soaring
I used my Powerflarm core gps out to send a signal to the SN10B. I don't remember exactly which color wire, but it was in the manual. The tricky part was the wire was so small and delicate that I had issues with vibration related failures. Mainly because I did it on the fly with small grey wire nuts rather than crimping or using block connectors.
Old May 24th 16, 04:34 PM posted to rec.aviation.soaring
Dave Nadler
Yes, hundreds of pilots use this combination...
The 9 pin connector you mentioned above.
See instructions he
http://www.nadler.com/sn10/SN10_Resource_Index.html
Old May 24th 16, 08:00 PM posted to rec.aviation.soaring
kirk.stant
Uli
I've been using my PF to drive my SN10 and Oudie for several years now with no problems. Use a cable from Cumulus designed for it; not cheap but worth it.
PF provides both GPS and Flarm info to SN10 and Oudie, SN10 provides vario and winds to Oudie, Oudie has backup GPS in case PF fails. SN10 can declare task to PF if desired, too.
In my opinion, anyone looking for a budget flight computer/vario should snap up one of the used SN10s - until you get into the uber-glass cockpit displays, they are hard to beat for ease of use.
Kirk
66
Old May 25th 16, 01:51 AM posted to rec.aviation.soaring
AS
See instructions he
Hi Dave,
thanks for the link - that is the info/confirmation I was hoping for. As far as my comment regarding 'what connector to use', I was looking for a suggestion as to what hardware to use since the 9 pin subD cables are like starter cables compared to what is in the RJ cable.
Uli
Old May 25th 16, 01:53 AM posted to rec.aviation.soaring
AS
Uli
Kirk
66
Couldn't agree more! I like it a lot.
Uli
Old May 26th 16, 05:36 AM posted to rec.aviation.soaring
Here's a plug for the SN10: I have one in my Ventus 2. I've flown it for years. Now share an Arcus with the new"Uber" display. I surely miss the SN10 navigation page which simply and clearly displays all data needed! With the SN10, I fly with the navigation page displayed 95% of the time. Simple, uncluttered, just what an aviator needs. Need a moving map? Just look out the canopy, where your eyes should be, anyways. In many ways, wish we had an SN10 in the new Arcus.
That being said, if you fly in complex mountainous territory, such as the Alps, where there is a paucity of out landing fields and airports, a good moving map display really does offer a significant benefit. There, I fly withe the SN10 and a PDA running PocketStrePla. The PDA gets data from both Flarm and SN10. Flarm is mandatory in Europe, and a great help in the glider congested classic routes. I'm a big fan of Flarm, and from experience,can say it is a great benefit. Just to clarify: 60% of my flying is in the Midwest USA, 40% in the European Alps
You are spot on: at current second hand market prices, the SN10 is unbeatable for value
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 05:31 AM
Mux, 302, Flarm Core, Dell Streak Blake Seese 9V Soaring 5 April 27th 15 04:06 PM
PowerFLARM Core secondary FLARM antenna [email protected] Soaring 27 October 7th 14 02:53 PM
FLARM Core weight [email protected] Soaring 6 May 11th 13 08:21 PM
Cabeling of ILEC SN10B with Flarm mkaiser Soaring 4 July 12th 10 05:04 PM
