The "Complex" TAS calculation
Old December 13th 03, 03:11 AM
Arnold Pieper
Default The "Complex" TAS calculation
Although TAS is not as useful for glider pilots, as IAS and GS, some recent
posts seem to sugget that TAS is not a clear concept for many pilots.
Some people even consider it a "Sophisticated calculation", which is really
astonishing.
The advent of GPSs with the easy read out of Ground Speed has led to further
missunderstanding of what TAS really is or how it's calculated.
There's nothing "complex" about it, pilots have been doing it for decades,
way before electronic cockpits, using a simple piece of plastic called a
circular E6B computer (under 10 bucks in any pilot shop).
Simply slide the circular calculator so that in the TAS window your current
Altitude is directly above the Outside temperature.
The TAS can then be read on the outer scale, associated with the IAS in the
inner scale.
Don't have an OAT (Outside Air Temperature) reading ?
Try and get it over the radio from someone who does, or calculate it based
on the temperature on the ground below you (stardard lapse rate).
There's also a rule of thumb to "estimate" TAS without considering
temperature, which is :
Add 2% to the IAS for every 1000ft of altitude above sea level.
Its just a rough estimate, and I don't recommend using it for wind
calculations, since small innacuracies here can cause some crazy wind
vectors.
From a Glider pilot's perspective, TAS is used mostly for calculating the
Wind in flight, whether or not you have a GPS.
Modern gliders usually have a Thermometer in the dash somewhere, with the
temperature sensor installed in some ventilation opening (out of direct
sulinght).
On-board flight computers such as ILEC, Zander, Cambridge, already come with
the temperature sensor, so that they can calculate TAS by themselves, and
thus know what the real glider's performance is, as well as what the real
wind is.
Without TAS they can't calculate wind accurately, although some use
Thermalling drift to update the wind vectors, which works well if you
thermal a lot.
Long cross-countries in mountain wave may involve very little circling, and
that's when you need a better method.
AP
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 09:04 AM
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? Jack Allison Owning 12 June 14th 04 09:01 PM
Seeking Complex Airplane Owners who are CFIIs Richard Kaplan Instrument Flight Rules 0 March 20th 04 10:05 PM
My first hour in a complex aircraft, the Beech V35B Peter R. Piloting 19 March 1st 04 06:27 AM
Complex Aircraft Question Chris General Aviation 5 October 18th 03 05:40 AM
