Cirrus vs ASW
Old March 12th 06, 02:00 AM posted to rec.aviation.soaring
Default Cirrus vs ASW
Thanks for all of the advise. I dont think I can afford
a B or C and I have made 2 minor errors in preflight
in all of my hours. Any suggestions on a 25k and under
sailplane would be appreciated.
Jeff
Old March 12th 06, 02:15 AM posted to rec.aviation.soaring
Jeff
I have twice owned an LS-3 -- the original model with the 175 pound
wings. If you have a Komet trailer, it isn't hard to rig an LS-3, and
there is no way to put it together without hooking up all the controls.
They rarely come on the market, but when they do they are dirt cheap
-- probably no more than $20,000. That would leave you $5,000 for all
the instrument and other upgrades that inevitably come with a new glider.
Other than the heavy wings, it is difficult to find fault with the
original LS-3, and the wings really are not bad -- two people can easy
rig in 5 minutes. The newer -3a model has lighter wings, but a manual
hookup for the ailerons, and is considerably more expensive.
Old March 12th 06, 02:35 AM posted to rec.aviation.soaring
Well as noted by Marc previously...with a hotellier
fitting on the elevator...getting it right 99% of the
time means you die.
Jeff
Old March 12th 06, 09:36 AM posted to rec.aviation.soaring
Jeff
I take it you have looked at:
www.wingsandwheels.com/wantads1.htm
Its great to see what types of gliders are/have been
on the market and the prices they go for.
With your budget, I can see a nice ASW19 for $22,500,
a Jantar for $18000, even a LAK12 (~48:1!!) for $20,500.
I really use it as an eye-opener to what is going around.
LAKs by the way are great machines and have flaps.
At almost 50:1 the performance per dollar cant be matched.
Just make sure you have done a bit of work with bigger
wings (20.5m)....
A friend at my club owns one and has never had any
problems with it, apart from it being a bit heavy on
the rigging side. He made a field landing last week
- late selection, landing in waist high crop, the glider
ground looped and came to rest within 2 fuselage lengths
of touching down. He walked away and the glider didnt
have an ounce of damage.
A glider like that at a price like that means (as someone
has already mentioned) you have a spare $4500 to do
upgrades or just to pocket the difference for those
aerotows!
As with any glider, each has its own characteristics
and should be respected. Do not be put off by flaps
or slightly bigger wings - its just a case of getting
some practice in a 2seater and then taking a day which
you can stay up a long time and get a feel for the
thing.
Hope this is of help,
JR
Old March 12th 06, 10:20 AM posted to rec.aviation.soaring
The best cheap glider is the Pegasus, by far. But as others have said,
there are at present problems, since the producer Centrair has
abandoned production, and there is a stupid 3000 hours limit. While
these problems are not cleared, it is perhaps not reasonable to buy one.
It is certain that these problems will be cleared since the Pegasus
is the basic club glider in France, there are a large number in use,
and these clubs will do everything necessary to get out of this trap.
Jeff
Michel TALON
Old March 13th 06, 06:07 PM posted to rec.aviation.soaring
Jeff
Michel TALON
That would be very nice if the Centrair would deal with the 3000 hours
issue.
Jacek Kobiesa
Washington State
Old March 13th 06, 06:21 PM posted to rec.aviation.soaring
In France, there is no 3000h issue with the Pegasus. The issue stems from
the FAA's interpretation of the service note, but it is still an issue for
the US and Centrair doesn't seem to be very responsive...
Jeff
Michel TALON
issue.
Jacek Kobiesa
Washington State
Old March 13th 06, 07:19 PM posted to rec.aviation.soaring
Oh, i see! then the question is much more serious that i thought, because
there is no big incentive to strongarm Centrair.
Michel TALON
Old March 13th 06, 08:27 PM posted to rec.aviation.soaring
You can say that again...
Half of our club's ships are 101As and 2 off them are grounded as a
result of this. :-(
Worse, we've been waiting months for a replacement part that a more
attentive factory should have had little trouble providing.
Jeremy
Cirrus demo Dan Luke Piloting 12 December 4th 05 06:26 AM
New G-1000 182 & Cirrus SR-22 GTS Dan Luke Owning 22 June 27th 05 08:18 PM
New G-1000 182 & Cirrus SR-22 GTS Dan Luke Piloting 24 June 27th 05 08:18 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 11th 04 12:30 AM
