Cobra trailer trim.
Old July 18th 06, 04:57 PM posted to rec.aviation.soaring
Bob
Default Cobra trailer trim.
Does anyone have any experience or comments on replacing the vinyl trim
that runs the length on both sides of the trailer. (Mine has faded over
the years but otherwise good.)
What's involved and how difficult?
Bob
Old July 18th 06, 05:32 PM posted to rec.aviation.soaring
Greg Arnold
I can't answer this (mine has faded too), but I've got a
related question - where can I get brake shoes for a Cobra
trailer?
Try Williams Soaring in N. California.
Old July 18th 06, 06:02 PM posted to rec.aviation.soaring
Gary Evans[_1_]
Yes, unfortunately I do. My original red strips faded
to black within 2 years and then started cracking.
Just received a set of replacement strips directly
from Cobra for $216 US delivered (not cheap). They
slide onto channels on the frame. Looks easy enough
for a couple of people to install. You have to trim
the ends and refasten with pop rivets included.
the vinyl trim
Bob
Old July 18th 06, 06:31 PM posted to rec.aviation.soaring
Bela Szalai
You are lucky. My red trim turned black in just one summer. Colorado UV.
Once it became uniformly black I learned to accept it.
I also learned to replace O-ring in the hydraulic ramp jack in 30 minutes,
an annual chore.
It looks like I need to replace the right tire about every 12-15 K miles,
since wheel toe is not adjustable, replacements easily beats cost of new
axle.
- Béla
------Original Message-----
-Sent: Tuesday, July 18, 2006 8:41 AM
-To: Bela Szalai
-Subject: [r.a.s] Cobra trailer trim.
-Newsgroup: rec.aviation.soaring
-Subject: Cobra trailer trim.
-Author: Greg Arnold
-Date/Time: 15:30 18 July 2006
-T o d d P a t t i s t wrote:
- "Bob" wrote:
- Does anyone have any experience or comments on replacing the vinyl
- trim that runs the length on both sides of the trailer. (Mine has
- faded over the years but otherwise good.)
- I can't answer this (mine has faded too), but I've got a related
- question - where can I get brake shoes for a Cobra trailer?
-Try Williams Soaring in N. California.
Old July 18th 06, 07:08 PM posted to rec.aviation.soaring
Greg Arnold
an annual chore.
Do you make your own O-ring, or do you have a source for one that fits?
axle.
- Béla
Old July 18th 06, 09:43 PM posted to rec.aviation.soaring
chipsoars
Anyone know where I can get the weatherstripping seal on the bottom
half of the trailer. This is what the clamshell closes against.
Also, has anyone replace lights with LED's and mounted a high center
stop light? What bulbs are in the tail lens?
Chip F.
Old July 18th 06, 10:31 PM posted to rec.aviation.soaring
Bob
Thanks for the info.
Are the 'new' weather strips UV resistant or will they too fade with
time?
Bob
the vinyl trim
Bob
Old July 19th 06, 12:29 AM posted to rec.aviation.soaring
Bubba
First, purchase from Williams Soaring (best price).
Second, The new stuff is difficult to slide into the channel. The
secret is to have 3 people. One person pulling, one pushing and one
feeding makes all the difference.
One person impossible
Two people, all day task
Three have it done in 30 minutes.
Bob
Old July 19th 06, 12:45 AM posted to rec.aviation.soaring
Bela Szalai
How long does it lasts? Same as original?
- Béla
-Sent: Tuesday, July 18, 2006 3:41 PM
-To: Bela Szalai
-Author: Bubba
-Date/Time: 22:30 18 July 2006
-First, purchase from Williams Soaring (best price).
-Second, The new stuff is difficult to slide into the channel.
- The secret is to have 3 people. One person pulling, one
-pushing and one feeding makes all the difference.
-One person impossible
-Two people, all day task
-Three have it done in 30 minutes.
- What's involved and how difficult?
- Thanks,
- Bob
Old July 19th 06, 02:58 AM posted to rec.aviation.soaring
trailer?
Make sure you get the right shoes for your trailer. When I called Rex
he didn't have the vintage-1987-type so I ordered a set from Cobra.
Get the instructions for adjusting the brakes. Adjusting the brakes
correctly might make you believe you've changed the shoes and cut the
drums.
info AT cobratrailer DOT de
And, while you're down there...
Everybody should have the newer "beer friendly" plastic fenders (mud
guards) with the flat spot on top. Rex has those complete with black
wheel chocks that take UV exposure better than white ones.
I took my old shoes to a brake shop in Pomona Ca and had them relined it can be done as long as you haven't let them get into the steel and have the drums turned at the same time. Price for 4 shoes & 2 drums turned $40.
LED lights can be bought at any big truck trailer supply such as
Utility or Trailmobile. Tail , brake & turn on my glass top cobra work
and look great, but I had to take a flapper wheel on a die grinder and
enlarge the holes out to 4". Side marker lights I used are (and tails)
Maxima brand didn't even have to drill new screw holes bolted right on
and took 30 min to do all 4.
Help - Cobra Trailer Trim? WDM Soaring 2 January 12th 05 08:47 PM
Cobra Trailer Hookup [email protected] Soaring 12 January 12th 05 04:08 PM
COBRA Skin Trailer Protector - Commercial John Seaborn Soaring 0 July 20th 04 05:38 PM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 03:06 PM
Cobra trailer fittings for different glider makes & models John W Soaring 4 September 24th 03 04:21 PM
