Strapping a Tri-pod into a Cardinal...
Old November 27th 06, 11:27 AM posted to rec.aviation.piloting
Default Strapping a Tri-pod into a Cardinal...
So I've decided to film some of my flights now during the rainy season
(really fun flying in Hawai'i during that time), and I was wondering if
anyone has any advice on how to strap a camera on or not on a tripod
into a plane, preferable on the tripod so I can move it around as I
desire (pan it left to right). Thanks for your guys help.
Old November 27th 06, 05:18 PM posted to rec.aviation.piloting
Newps
Forget the tripod. Go to the store and get a sponge or two. The camera
sits on the sponge on top of the glareshield. Then take elastic straps
and attach a ring terminal to both ends. Attach ring terminals to
convenient sheet metal screws on the glareshield. My 182 had an
avionics access panel that I used. The sponge keeps the camera from
vibrating. The easiest video cameras to use have the flip open screen.
Set the camera to the scenery mode so it won't focus on the
windshield. I always had just a little bit of the engine cowl in the
lower part of the screen for reference. If you use a Sony camera you
can plug a cord from the intercom directly into the mic in jack, no
special cords needed. The only downside to audio is you either get
constant engine drone or no engine drone and communications.
Old November 27th 06, 08:37 PM posted to rec.aviation.piloting
randall g
On 27 Nov 2006 02:27:58 -0800, "
Check out this guy:
http://www.youtube.com/profile?user=fholbert
randall g =%^) PPASEL+Night 1974 Cardinal RG
http://www.telemark.net/randallg
Lots of aerial photographs of British Columbia at:
http://www.telemark.net/randallg/photos.htm
Vancouver's famous Kat Kam: http://www.katkam.ca
Old November 27th 06, 10:38 PM posted to rec.aviation.piloting
Well I rather like the method used in the article supplied by Kev...
the only thing I wonder is if the tripod is going to be affected by
pitch and bank, I guess the two bungee cords will hold it against
lateral and probably verticle acceleration, but I want to be sure it's
going to be okay when the plane is banking about 20 degrees.
Also, I don't want to use the spnge method because I don't want the
standard "over the dash" shot that you see in many cars and planes, I
want to use my 0.5X lens and get the shot from just above eye level
from the back seat, so you can see the instrument panel and out the
plane and me and any pax/other pilot sitting up front, a better angle I
think.
Old November 27th 06, 11:22 PM posted to rec.aviation.piloting
Jay Beckman
think.
One problem:
The contrast ratio is just too much for a video camera to handle (or even a
film camera for that matter...) so you won't be able to properly expose both
the view outside and your panel without some creative filtration. One
alternative (rather than totally covering your windscreen with ND) is to get
a split ND (Neutral Density) filter and align it with the line formed by
your glareshield. About 4 stops worth ought to be a good starting point.
Without the ND, you'll have either a properly exposed panel and blown out
views outside or a pristine outside view with a black hole where the panel
should be.
Good luck with your project.
Jay Beckman
PP-ASEL
Chandler, AZ
PS...One suggestion for securing the tripod: See if you can find a way to
exert a strong downward pull. You'll notice serious nature photographers
get this by hanging their camera bags or sandbags on hooks at the bottom of
the center column of their tripods. Chain it or MilSpec bungee cord it to
the floor of your cabin if you can.
Old November 27th 06, 11:56 PM posted to rec.aviation.piloting
Luckily I do have a ND filter, so I will use that, and I'm also going
to screw on the $40 polarizing filter I have, that works impeccably
when filming free-hand.
I was thinking of doing that, also getting a longer bungee cord and
running it under the seat to the two forward cargo loops, that should
give it plenty of tug, and then I think that bungee-ing it somewhere
into the side rails should provide enough pull to keep it from leaning
around during banks.
Should be a fun DVD to put together as a general guide to the airport
around here, theres only 16 you can land at... fun huh, you can
memorize all the procedures (not that is would be a smart idea).
Old November 28th 06, 01:59 AM posted to rec.aviation.piloting
Jay Beckman
a
both
get
Just be sure you employ it as a split field filter. You only want to knock
down the amount of light coming in the windscreen so the iris can open up
for proper exposure of the cabin/panel. I would not use a polarizer
however. You run the risk of seeng all kinds of rainbows caused by stresses
in the plexi and your exposure will be inconsistent depending on the
location of the sun. The polarizer will have it's greatest effect when the
sun is at your three or nine o'clock and virtually none when the sun is at
your 12 or six.
of
to
I was thinking of doing that, also getting a longer bungee cord and running
it under the seat to the two forward cargo loops, that should give it
plenty of tug, and then I think that bungee-ing it somewhere into the side
rails should provide enough pull to keep it from leaning around during
banks.
Or, maybe down and back through the rear seat + down and forward to the very
aft end of the front seat rails? I'm not familiar with what's available in
a Cardinal when the seats are racked forward.
around here, theres only 16 you can land at... fun huh, you can memorize
all the procedures(not that is would be a smart idea).
More than one professional video production that I've worked on got started
with "What If...?"
Good Luck...
Jay B
Old November 28th 06, 05:01 PM posted to rec.aviation.piloting
Jose[_1_]
You can't have both in focus.
Sure you can, if you use a split diopter (essentially bifocals for a
camera).
Jose
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
Cardinal 177A 1968 advice [email protected] Owning 17 November 24th 05 08:02 AM
Flying our Cardinal south for its new plumage - Long report Longworth Piloting 20 October 20th 05 06:01 AM
Flying our Cardinal south for its new plumage - Long report Longworth Owning 19 October 20th 05 01:23 AM
folding bicycle - Cardinal RG Stephen N Mills Piloting 2 January 11th 05 03:13 AM
Any Cardinal owners that frequent this group? Jack Allison Owning 6 November 17th 04 04:05 PM
