Light twins not using contra-rotating propellers
Old December 1st 06, 03:35 AM posted to rec.aviation.piloting
Capt.Doug
Default Light twins not using contra-rotating propellers
"Mark Levin" wrote in message
As was pointed out to me the Beechcraft Baron does not use contra-rotating
propellers. A bit of research showed me that most U.S. built light twins
do
not use them either.
My question is why?
Cost has been pointed out, however the Piper Navajo Chieftain has
counter-rotating props (as opposed to contra-rotating) and no one mentions
that they didn't buy a Chieftain because of the extra cost. The internal
engine parts that differ from each side are well stocked by parts suppliers
and therefore differ little in price from each other.
Not mentioned by other posters is that stability in twins can be affected by
which way the props rotate. The P-38 Lightning and Ted Smith Aerostar are
examples of this. Counter-rotate the props one way and get better
performance at the cost of stability. Turn the props in the opposite
direction and get better stability at the cost of performance.
D.
Old December 1st 06, 07:43 AM posted to rec.aviation.piloting
Mxsmanic
Capt.Doug writes:
These aircraft allow you to select the rotation direction of the
props?
Old December 1st 06, 08:07 AM posted to rec.aviation.piloting
On Fri, 01 Dec 2006 07:43:40 +0100, Mxsmanic wrote:
Capt.Doug writes:
props?
No, different models of the same aircraft turned the engines different ways.
For example:
First P-38: http://p-38online.com/images/xp381.jpg
Second P-38: http://p-38online.com/images/yp38grnd.jpg
Look at the direction of rotation of the port engine.
Light twins not using contra-rotating propellers Mxsmanic Piloting 120 December 5th 06 01:49 AM
Light twins not using contra-rotating propellers RomeoMike Piloting 6 December 2nd 06 02:47 AM
Light twins not using contra-rotating propellers Jim Macklin Piloting 6 December 2nd 06 02:41 AM
Light twins not using contra-rotating propellers Newps Piloting 0 November 30th 06 08:40 PM
Light twins not using contra-rotating propellers Greg Farris Piloting 0 November 30th 06 08:25 PM
