slips to landing in PTS
Old April 15th 07, 05:23 PM posted to rec.aviation.soaring
BB
Default slips to landing in PTS
RAS fans may be interested in the results of an investigation by an
instructor/examiner in our club. The question is, do the PTS really
require a slip all the way to landing without ever touching the
spoilers?
(Why? We fly from a short runway, surrounded by houses and trees, and
we have modern, low drag gliders rather than 2-33s. For us, this is a
chancy maneuver with an experienced instructor in back, and clearly
dangerous to send solo students off to practice it on their own.)
It turns out the answer is no; not only is the maneuver not part of
the PTS, the FAA says examiners should not ask for it. But many
examiners and FSDOs don't know this, and think that the maneuver is
required.
The official guidance is in the January 2000 designee update. Here's
the relevant text:
We have had questions on whether the applicant
should complete the landing, with or without the
use of drag devices.
There was never any intent to require an applicant to
complete the landing without the use of drag
devices. The applicant is only required to
demonstrate a slip (forward or side) without using
drag devices, to position the glider for a safe
landing. Element 6 of the TASK states; "make
smooth, proper, and positive control applications
during recovery from the slip." Once this has been
accomplished, the maneuver being evaluated is
over. The applicant then lands the glider within the
designated landing area, using drag devices as
appropriate.
Most important for examiner standardization, the
examiner should not add or decrease elements to
this task, or any other task, by asking the applicant
to do more or less than is required.
The direct link is below, but will get broken up. You can find it by
googling "faa desingee update."
John Cochrane BB
http://www.faa.gov/other_visit/aviat..._01_Update.pdf
Old April 15th 07, 07:05 PM posted to rec.aviation.soaring
Nyal Williams
Instructors who attend CFI-G re-validation clinics
know this; it is discussed there regularly. Even if
you (CFIs at large) get your renewal via powered aircraft
venues or by having large numbers of successful candidates,
it is a good idea to attend these clinics for the knowledgeable
and sometimes heated discussions with a room full of
CFI-Gs.
by an
the PTS really
touching the
spoilers?
and trees, and
For us, this is a
and clearly
on their own.)
not part of
it. But many
the maneuver is
required.
update. Here's
the relevant text:
to
landing. Element 6 of the TASK states; 'make
during recovery from the slip.' Once this has been
appropriate.
can find it by
googling 'faa desingee update.'
John Cochrane BB
http://www.faa.gov/other_visit/aviat...ignees_delegat
ions/designee_news/designee_updates/media/2000/2000_01_Update.pdf
Old April 15th 07, 09:36 PM posted to rec.aviation.soaring
Bill Daniels
You are correct on both points. It isn't required and many CFIG's & DPE's
don't know that. In fact, as you also point out, there is danger involved.
A danger is that a slip may taught as an alternative to spoilers - a trick
to have in your back pocket "just in case".
If a pilot of a slick, high performance glider mis-identifies the spoiler
handle and, seeing no result from whatever handle he is pulling, reverts to
a slip to complete the landing, he will almost certainly overshoot. Better
training is to teach the pilot to identify why the 'spoilers' are having no
effect - i.e. look at the handle.
High performance gliders will slip nicely, but the resulting descent rate is
often not high enough for a normal approach and landing - particularly not
if the approach is begun with too much energy.
I'm glad to see the FAA clarifying the slip requirement in the PTS.
Bill Daniels
"BB" wrote in message
spoilers?
required.
the relevant text:
appropriate.
John Cochrane BB
Old April 16th 07, 09:15 AM posted to rec.aviation.soaring
Bert Willing
With a Janus, DuoDiscus, ASW19... it is certainly a very efficient
alternative to airbreaks.
"Bill Daniels" bildan@comcast-dot-net wrote in message
involved. A danger is that a slip may taught as an alternative to
spoilers - a trick to have in your back pocket "just in case".
to a slip to complete the landing, he will almost certainly overshoot.
Better training is to teach the pilot to identify why the 'spoilers' are
having no effect - i.e. look at the handle.
is often not high enough for a normal approach and landing - particularly
not if the approach is begun with too much energy.
Bill Daniels
spoilers?
required.
the relevant text:
appropriate.
John Cochrane BB
Old April 16th 07, 04:54 PM posted to rec.aviation.soaring
Bill Baker[_2_]
and trees, and
For us, this is a
and clearly
on their own.)
What is the length of your runway?
Why is it a chancy maneuver with an experienced instructor
in back?
Do your instructors send solo students off to practice
rope breaks on their own?
Old April 17th 07, 06:07 AM posted to rec.aviation.soaring
Andy[_1_]
On Apr 16, 12:15 am, "Bert Willing" willing_no_spam_ple...@ir-
For the ASW-19b the slip is also a very effective augmentation to
full airbrakes. I regularly practiced full rudder, full airbrake,
slips and used the technique more than once in a tight off airport
landing.
Andy
Old April 17th 07, 06:58 AM posted to rec.aviation.soaring
Roger Worden
The first FAA examiner I encountered misinterpreted the PTS as you
describe... insisting on slipping all the way to landing without spoilers. I
canceled my test when I learned that, since I had not been trained on it.
After trying it a few times with and without an instructor, we concluded
that it was unlikely to be accomplished by a student pilot within the
allowed distance. I researched it and found the designee update... went back
to the FAA... and found that the guy had retired! The next guy understood
the actual requirement. This caused me about a 2-month delay in taking my
test.
spoilers?
required.
the relevant text:
appropriate.
John Cochrane BB
Slips and spins in FSX? Chris Wells Simulators 0 December 14th 06 09:24 PM
About forward slips Mxsmanic Piloting 77 November 3rd 06 12:35 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 06:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 05:01 AM
landing franck jeamourra Owning 1 February 10th 04 10:29 AM
