oil pressure problem
Old June 5th 07, 08:40 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default oil pressure problem
I'd like some advice where the problem is no reading on the gauge ( and can
use a Volt-ohm-meter if have to).
It is a three wire Electric gauge and a bell shaped sensor with the lead
attached at the top. Although upon sensor removal, there was oil pressure
(squirting G).
Could I check for meter needle deflection by striking the disconnected
sensor lead to ground or will that destroy the meter? Could I apply some
air pressure to the sensor and read a resistance change?
Thanks, Dick
Old June 6th 07, 12:59 AM posted to rec.aviation.homebuilt
1st. Verify the sender is working by removing the single wire and
attaching your
ohm meter from the output to a known good ground. If the sensor is
good, you will
get a varying number as pressure changes.
2nd. Check for voltage coming from the gauge lead with a/c power on.
3rd. Check for voltage to the gauge and the light, also checking the
the case does
have a good ground.
If all check out ok, hang a mechanical gauge to verify that you do
have pressure.
Old June 6th 07, 12:10 PM posted to rec.aviation.homebuilt
Dick[_1_]
cvairwerks.
Thanks for the advice. I'll try tomorrow.
Noting your email address, I thought I'd advise that the engine is a Corvair
in a Midget Mustang project. Been so long since I built it that I forgot
where the original automotive temp and pressure sensors were located on the
engine. I have a "tree" with oil pressure and temperature sensors on top
and alongside the plugged mechanical fuel pump opening.
Would you advise where the original oil press/temp sensors were installed?
Thanks, Dick
"Dick" wrote in message
news:l_i9i.33$ng.32@trnddc07...
can use a Volt-ohm-meter if have to).
(squirting G).
Thanks, Dick
Oil pressure problem Aluckyguess Piloting 17 January 5th 07 11:50 AM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
Oil Pressure Justin H Home Built 2 September 23rd 04 04:35 AM
Oh, the pressure! Andrew Gideon Piloting 10 April 20th 04 05:54 PM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
