Flight Data Recorders
Old September 7th 08, 12:36 PM posted to rec.aviation.piloting,aus.aviation
Michael Henry[_2_]
Default Flight Data Recorders
I was reading this article about a Russian air crash - here is an excerpt...
Russian investigators have discovered that the cockpit-voice
recorder from the crashed Itek Air Boeing 737-200 contains no
trace of the ill-fated jet's final flight.
MAK adds that the quality of the flight-data recorder information
is "unsatisfactory" because of partial thermal damage to its
magnetic tape, caused by the intense fire which followed the crash.
Which made me think: magnetic tape?! Surely we've come far enough that
we can be using solid-state storage in flight data recorders?
Does anyone know why FDRs would still be using what, to me, is archaic
technology?
Old September 7th 08, 02:18 PM posted to rec.aviation.piloting,aus.aviation
Tman
*Russian* ??
excerpt...
technology?
Old September 7th 08, 02:24 PM posted to rec.aviation.piloting,aus.aviation
Stealth Pilot[_2_]
On Sun, 07 Sep 2008 20:36:59 +1000, Michael Henry
technology?
gee give them a chance! they've only just stopped using wire
recorders.
Old September 7th 08, 05:55 PM posted to rec.aviation.piloting,aus.aviation
Peter Dohm
"Michael Henry" wrote in message
excerpt...
Which made me think: magnetic tape?! Surely we've come far enough that we
technology?
This occasionally happens, even though the FDR and CVR have considerable
thermal inertia and are located in a part of the plane that is least
frequently affected by both fire and mechanical damage. Also, the prose
above suggests that there was some data recovered from the cocpit voice
recorder and "some data" is probably more than they would have gotten from
solid state memory.
All the same, there has been a move from magnetic tape and metal foil to
solid state memory in the 20+ years that I have been out of that industry.
However, IMHO, that has been a case of obtaining more detailed data and
information (most of the time) and greatly reduced maintenance cost (the
frequent replacement of tapes and foils was shop maintenance) and accepting
far less robust media in order to accomplish those goals.
Personally, I can see more than one side of the arguments leading to these
changes and I have mixed feelings regarding the wisdom of same.
Peter
Old September 7th 08, 11:51 PM posted to rec.aviation.piloting,aus.aviation
Sr20goer
"GB" wrote in message
Michael Henry wrote in news:00d3a924$0
SNIP
It's not all that archaic. Aviation trails the bleeding edge by a
very long margin, and with good reason. The bleeding edge usually
draws blood at some point! I was initially surprised to learn, in
circa 1999, that the B767 didn't use GPS for navigation. I
subsequently learned that they don't need it... GPS isn't really
up to scratch. (I'm not gonna explain that here, that's fodder
for another post!)
GB
GB
You referring to INS?
But they do now use GPS for 'local' navigation (SID, STAR, flextrack etc).
Brian
Old September 8th 08, 01:06 PM posted to rec.aviation.piloting,aus.aviation
Sr20goer
"Sr20goer" wrote in
etc). Brian
Yes I am, and yes I know. My (maybe badly made) point was that
the new technology wasn't adopted for a very long time after
it had become 'mainstream' in other fields.
GB
No, not badly made, I was just wanting to check it was INS.
I agree re aviation 'lagging' with technology - same philosophy as you,
partly 'accreditation' of equipment, partly 100.1% safety requirement
cheers
Brian
Old September 8th 08, 03:08 PM posted to rec.aviation.piloting,aus.aviation
David Lesher
Michael Henry writes:
technology?
Co$t is why. And while flash-based systems may offer more survivable
recording; consider the recent Qantas incident, where the
depressurization itself was overwritten by subsequent flight.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old September 8th 08, 10:46 PM posted to rec.aviation.piloting,aus.aviation
Bertie the Bunyip[_25_]
"Sr20goer" wrote in
news:00d3a924$0 :
SNIP
for another post!)
GB
GB
etc). Brian
No, they use GPS to update the INS.
Bertie
Old September 8th 08, 11:35 PM posted to rec.aviation.piloting,aus.aviation
Peter Clark
On Mon, 8 Sep 2008 13:08:56 +0000 (UTC), David Lesher
technology?
They could put in a bigger chip for longer recording. I thought most
DRs were only about 1/2 hr looping?
Old September 8th 08, 11:57 PM posted to rec.aviation.piloting,aus.aviation
Sr20goer
"Sr20goer" wrote in
news:00d3a924$0 :
SNIP
GB
etc). Brian
Bertie
Bertie
Can we call it one all?
I'm talking of the derivation of the nav data - the GPS engine is used for
local navigation data, how it gets to the display may well be via the INS
but the GPS engine is still the source.
cheers
Brian
Why so expensive (flight recorders) Jim Beckman Soaring 64 March 4th 08 03:18 PM
Standalone Flight Recorders for Club Use ContestID67 Soaring 8 April 24th 07 02:27 AM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 06:09 PM
Commercial - Mounts for GPS Flight Recorders Paul Remde Soaring 0 March 13th 04 03:03 PM
Approved IGC Flight recorders mat Redsell Soaring 2 March 5th 04 04:35 PM
