How can the Magnus effect be explained with Bernoulli?
Old June 20th 09, 09:04 PM posted to rec.aviation.piloting
Mikki
Default How can the Magnus effect be explained with Bernoulli?
Hi folks,
According to Bernoulli’s principle, an increase of speed will be
accompanied by a decrease in static pressure. However, Bernoulli’s law
only pertains to flows without any external energy being added (or
removed).
That’s why I do not understand why Bernoulli can be used to explain
the Magnus effect.
If a clockwise rotating cylinder (Flettner-Rotor) is moved through the
air from right to left (i.e. free stream direction is from left to
right), this will cause the flow on the upper site (free stream
velocity + rotation) to be faster than on the lower site (free stream
velocity - rotation). More importantly, an upward lifting force acting
on the turning cylinder can be observed.
All books / internet sites I checked so far explain the lifting effect
by Bernoulli’s law (faster flow on the upper site of the cylinder
causes a drop in static pressure and hence lift).
However, I don’t see why Bernoulli applies here as the rotation of the
cylinder means to add additional energy to the free stream and thus
should not lead to a reduced static pressure, should it?
Therefore, I would be very grateful for any advice why the Magnus
effect can be explained with Bernoulli’s law.
Thank you
Mikki
First Magnus pilots [email protected] Piloting 0 April 4th 09 08:36 PM
black box explained houstondan Piloting 3 June 30th 06 05:55 AM
ADIZ Violation Explained in AOPA Magazine Jay Honeck Piloting 168 January 15th 06 03:49 AM
Magnus Effect COLIN LAMB Soaring 23 October 27th 04 08:02 PM
The bernoulli theory of starting a long thread David CL Francis Piloting 7 October 26th 03 08:40 PM
