Komet trailer tongue
Old February 4th 11, 12:31 AM posted to rec.aviation.soaring
key[_2_]
Default Komet trailer tongue
Questions for those of you with later model (extruded aluminum sides)
Komet trailers. On mine the tongue clunks when braking moderately or
starting to roll as the tongue takes up slack--is this normal? Also,
the hitch rotates to the right as far as it can go when trailering--is
this normal? Would appreciate your thoughts.
Key
Old February 4th 11, 01:24 AM posted to rec.aviation.soaring
JS
There is a damper inside the tongue. Eventually it fails, and these
noises are probably an indicator of that. On the Wings And Wheels
website Tim has put a diagram and some directions on how to replace
this part. I have replaced a couple of these on Cobra trailers.
The tongue is manufactured by Alko, and there are many different
shocks so contact the Komet distributor with information on the
trailer year and all the numbers on the tongue that you can find.
http://www.wingsandwheels.com/Tongue%20detail.htm
Old February 4th 11, 03:18 AM posted to rec.aviation.soaring
lanebush
On Feb 3, 8:24*pm, JS wrote:
* There is a damper inside the tongue. Eventually it fails, and these
* The tongue is manufactured by Alko, and there are many different
Jimhttp://www.wingsandwheels.com/Tongue%20detail.htm
On my Eberle I removed the strut and had the Monroe rep match it to
one of their steering struts. It was slightly different than the old
German version but works great. I researched the German version by
the info stamped on the housing. It turns out the company now builds
stabilizers for tanks. My strut was long ago out of production! Now
it is all smoooth sailing.
Lane
Old February 4th 11, 05:10 AM posted to rec.aviation.soaring
T8
Komet trailers. *On mine the tongue clunks when braking moderately or
starting to roll as the tongue takes up slack--is this normal? *Also,
this normal? *Would appreciate your thoughts.
Key
Probably, you need to adjust your brakes as well as check the damper.
-T8
Old February 4th 11, 03:41 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Key
-T8
If you don't replace the dampnere, the brakes will come on hard as you
slow down, this will make the hitch pull out and release the brakes.
Then it all starts over again. Roll the window down and apply some
auto brakes, you may hear, "chirp.......chirp......chirp" as the above
trailer action is happening and also BTW eating your trailer tires.
Ask me how I know this?
JJ
Old February 4th 11, 10:40 PM posted to rec.aviation.soaring
key[_2_]
Key
-T8
JJ
Thanks to all for your helpful comments!
Key
Old February 5th 11, 01:19 AM posted to rec.aviation.soaring
sisu1a
I think it might be binding in it's cheek. Lots of folks round here
swear by SuperLube, but in San Francisco AstroGlide is the #1 of
choice.
-paul
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Komet Trailer gas struts HL Falbaum[_2_] Soaring 13 February 1st 09 01:05 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
Trailer tongue failure [email protected] Soaring 8 March 17th 08 03:45 AM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
