Komet Trailer Rebuild
Old March 18th 15, 06:37 PM posted to rec.aviation.soaring
Robert Ballou
Default Komet Trailer Rebuild
I'm doing a partial rebuild on a 30 year old Komet trailer. I want to replace the large rubber gasket on the top of the tail gate, the Tee handle in the tail gate and the Tee handle on the front hatch. All this stuff has metric dimensions. I will replace parts with English dimensions only if there is no other option. Price quote from the German factory took my breath away ($230 USD). Does anyone know of a US supplier of generic versions of these parts?
Thanks,
Bob
Old March 18th 15, 08:10 PM posted to rec.aviation.soaring
Thanks,
Bob
I fabricated rear latch crank and rods for about $50 using 3/8 SS thick wall tubing and steel flat stock. I had the handle and shaft assembly. It took about 3 hours.
I scrapped the torn rubber thing and don't intend to replace it. The trailer needs more ventilation anyway.
Good luck
UH
Old March 18th 15, 09:02 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Bob, you might check McMaster-Carr. They have lots of options available. This could be a starting place to look.
http://www.mcmaster.com/#cam-latches/=wd7xsh
Steve Leonard
Old March 19th 15, 11:28 PM posted to rec.aviation.soaring
Robert Ballou
Steve Leonard
Thanks, Steve, this looks promising.
Old March 19th 15, 11:31 PM posted to rec.aviation.soaring
Robert Ballou
Thanks,
Bob
Good luck
UH
Thank you for this. I've been thinking of just taking the rubber off and maybe putting a self sacrificing square U channel of aluminum in place of it. I might possibly glue some thin carpet on there as an alternative.
Old March 20th 15, 02:40 AM posted to rec.aviation.soaring
Papa3[_2_]
If you ever tow the glider in the rain, I'd think twice about losing the tailgate gasket. I took mine off at one point intending to fix it and forgot about it. Towing back from a contest in the rain I ended up with dirty water on the wingtips and rudder. IIRC, I found a garage door weatherstrip that worked well.
I second the McMaster Carr recommendation.
P3
Old March 20th 15, 01:30 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
P3
They can help with that, too.
http://www.mcmaster.com/#bulb-seals/=we36mn
Disclaimer: I have no financial interest in McMaster Carr, but am a very satisfied customer.
Steve
Old March 20th 15, 01:48 PM posted to rec.aviation.soaring
P3
I suspect the rubber strip is more for protecting the aluminum door when it is on pavement. I may be worthwhile to add protection if the trailer is used that way. The door gap can easily be closed with foam attached to the top using hardware store foam.
Mcmaster part number for SS tubing for lock rods is 89895K739. Two 3 foot lengths required. Flatten on end in a vice about 1 inch and drill connecting shaft holes. Mine were 3/16.
UH
Old March 20th 15, 03:17 PM posted to rec.aviation.soaring
Robert Ballou
P3
Thanks for the garage door weatherstrip suggestion. And, my preference is to have a seal over not having a seal. -Bob
Old March 20th 15, 03:25 PM posted to rec.aviation.soaring
WAVEGURU
Reminds me of a joke....
Boggs
Komet Trailer Coupler [email protected] Soaring 0 September 19th 12 03:48 AM
Komet Trailer Parts Dan Mockler Soaring 3 May 1st 12 05:31 PM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Komet Trailer gas struts HL Falbaum[_2_] Soaring 13 February 1st 09 01:05 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
