Komet Trailer Parts
Old April 26th 12, 12:13 AM posted to rec.aviation.soaring
Dan Mockler
Default Komet Trailer Parts
I am looking for a US source for hub seals for my 1981 Komet
trailer.
Any guidance would be appreciated.
Dan Mockler
Old April 26th 12, 11:40 PM posted to rec.aviation.soaring
trailer.
Dan Mockler
Dan,
Try these folks, www.applied.com
I know that they have access to almost everything made.
If not then let me know and I will see what I can do.
BIll
Old April 29th 12, 02:47 PM posted to rec.aviation.soaring
RS
trailer.
Dan Mockler
Dan,
Try these folks,www.applied.com
BIll
Any luck with finding a source for Komet parts in the US? I have an
older (early 1980's?) Komet and have been having problems with the
ramp/jack. I did a quick search throught the website mentioned above
but didn't find anything.
Thanks
Old May 1st 12, 05:31 PM posted to rec.aviation.soaring
Dan Marotta
For a ramp jack you might look at an auto junk yard for a scissor jack. For
stability you should use two jacks ganged together. A friend told me long
ago to be sure the jacks are the same part number to assure the same lift to
crank ratio; otherwise, as you jack up the ramp, it will tilt.
"RS" wrote in message
trailer.
Dan Mockler
Dan,
BIll
Thanks
Komet Trailer Suspension Parts Randy[_2_] Soaring 4 December 15th 10 04:04 AM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
KOMET Trailer Cradle [email protected] Soaring 3 September 27th 04 04:33 AM
Komet trailer strut John Shelton Soaring 5 November 15th 03 05:04 PM
