Tost Lilliput brake question
Old May 22nd 19, 02:26 AM posted to rec.aviation.soaring
Dan Marotta
Default Tost Lilliput brake question
You might consider a brass or aluminum slug in the hole ahead of the set
screw.Â* That should lock the cable without damaging it (too much).
On 5/21/2019 12:00 PM, wrote:
No idea if this is original or not but the brake cable setscrew in my Libelle is a flat tip style. I haven't had any issue with the cable getting cut but it does flatten out the cable such that it becomes difficult to reuse a second time should you ever remove it. I have a mid-cable adjuster in addition to the adjuster nuts on the wheel end and it seems to give plenty of adjustment to keep things working well.
Robert
On Tuesday, May 21, 2019 at 12:49:01 PM UTC-5, Hartley Falbaum wrote:
On Tuesday, May 21, 2019 at 8:28:19 AM UTC-4, Hartley Falbaum wrote:
I am trying to improve the brakes on a Libelle 201B. I replaced the shoes and de-glazed the drum recently but not much help.
I trued the drum on a mandrel in a 10" Clausing lathe. I mounted the backing plate and shoes on another mandrel, intending to true the shoes, but got readings that told me the shoes would have to be expanded.
I had no good way to do that without getting excessive clearance. So I just deglazed them.
After installation, I had to max-out the one adjuster in order to get the proper tension on the handbrake.
I noticed a threaded hole in the brake handle, centered on the cable. Looks like a setscrew belongs there for adjusting cable length.
So--here's my question-----What style of setscrew point belongs there? Flat tip, or dog point (extended tip). I presume a cup point would damage the cable.
Thanks in advance for any factual knowledge.
Hartley Falbaum
hfalbaum at comcast dot com
Good suggestion!
The Lilliput brake arm is really hard to change spline alignment due to the coil spring around the base.
But my question was about a possible set screw in the handle to adjust the brake. appears to be M6-1.0.
could be used to adjust cable length, but the screw is missing. The threaded hole is there. Does anyone know for sure about this?
Thanks
Dan, 5J
Old May 22nd 19, 09:52 PM posted to rec.aviation.soaring
Hartley Falbaum
Mine (SN 470) has a hex-head bolt with a slot for a screwdriver. The end of the shank is flat.
Old May 22nd 19, 11:06 PM posted to rec.aviation.soaring
So if there is not setscrew in your brake handle, how is the brake cable attached? Does it go all the way through the handle and then have a soldered in stop sticking out from the back side? I've seen at least one other Libelle that was cobbled together incorrectly like that so just wondering.
Robert
Hartley Falbaum
Old May 22nd 19, 11:18 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Hartley Falbaum
Right--there is no setscrew. The cable has a swedged on copper end sleeve. It is not my glider. I'm thinking it does need the setscrew.
I like the aluminum slug idea.
Hartley
Looking for Tost Standard Drum Brake Wheel (USA) [email protected] Soaring 2 March 28th 19 12:11 PM
Modifying Std Libelle with Tost Lilliput Wheel [email protected] Soaring 10 September 19th 17 06:51 PM
Tost Disk Brake rebuild? Paul Cordell Soaring 10 April 17th 08 07:20 AM
Tost brake bolt shears off - the answer Jack Glendening Soaring 1 September 30th 07 01:16 PM
Tost brake bolt shears off Jack Glendening[_2_] Soaring 25 September 10th 07 10:15 PM
