Tail dolley wheels?
Old September 29th 19, 03:09 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Tail dolley wheels?
On Sun, 29 Sep 2019 13:11:43 +0000, John McLaughlin wrote:
Is it ok to use a solid rubber tyre for my tail dolly wheel, or do I
risk damaging the glider?
You don't say what the glider is or how your tail dolly works, which
would be useful information.
That said, I think a solid rubber tyre is fine *provided that* the dolly
is off the ground when the glider is being towed by a vehicle, i.e. the
weight of the dolly and rear end of the glider is carried by the tow
ball. The dollies for both gliders I've owned have been lifted off the
ground when the tow bar is attached to a vehicle. With this arrangement
the only time you'll move the glider on the dolly when is when the towbar
is detached and you're moving the glider slowly by hand, so having a
solid tyre is no problem.
The type of dolly that rolls along the ground when being towed by a
vehicle may benefit from having a larger wheel with a pneumatic type
fitted, but I have no experience of using this type.
Martin | martin at
Gregorie | gregorie dot org
Tail Wheels & Tail Booms snapp'n POPS Soaring 12 November 24th 11 02:00 AM
Tail Wheels & Tail Booms snapp'n db_sonic[_2_] Soaring 0 November 18th 11 08:35 PM
Tail wheels, or is this forum really dead? [email protected] Home Built 8 February 5th 10 01:33 AM
Source for tail wheels Simon Soaring 11 May 25th 05 04:05 AM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
