Paint for white fiberglass trailer top
Old June 22nd 20, 06:42 PM posted to rec.aviation.soaring
David Laitinen
Default Paint for white fiberglass trailer top
We have used reflective roof coatings such as Kool Seal. Seals up any
minor leaks and also reduces the temperature inside the trailer.
On 6/22/2020 12:49 PM, Tony wrote:
On my Komet I did a light sanding with a disc sander and then rolled on white house paint from Ace Hardware. It was a combo primer/paint, cant remember the brand. Still looks good a couple years later. I figured houses sit out in the sun all the time and the paint holds up pretty well
Old June 23rd 20, 12:36 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
I refinished a Komet trailer 3 yrs ago with Boat paint . Self leveled and didn't see any roller marks afterwards. Came out great, UV protection as well although about $50.00 a Qt. I sanded first with an orbital sander 150 and used 5 coats .
Very good coverage for a qt.
Also afterwards I used a white roofing silicone along the galvanized base .
https://www.jamestowndistributors.co...ide+Boat+Paint
Old June 23rd 20, 07:03 AM posted to rec.aviation.soaring
Senna Van den Bosch
Op dinsdag 23 juni 2020 02:43:12 UTC+2 schreef Delta8:
base .
http://tinyurl.com/yaudtp3z
Delta8
What's a Qt if I may ask? Or is that in liters? (I'm from EU)
Old June 23rd 20, 11:14 AM
Member
base .
Delta8
Quart
https://www.google.com/search?q=quar...hrome&ie=UTF-8
Old June 24th 20, 04:08 AM posted to rec.aviation.soaring
Bret Hess
I painted my trailer with HC-2500 Amerflint II polyurethane from Tamco paint. It's been in sun and snow year around for 3 years and still looks like it did the day I painted it. It's excellent...I'm painting my glider with it this month.
https://tamcopaint.com/products/dura...30875014496336 . You have to wear a passive carbon filter mask that traps organics while spraying, but it's no big deal.
Excellent customer service, too.
Old June 24th 20, 04:12 AM posted to rec.aviation.soaring
Bret Hess
For primer I used https://www.homedepot.com/p/Rust-Ole...0502/100126115 . I thinned it with urethane thinner and it worked great. Very tough stuff. (On my glider I'll use a urethane 2K primer, but this is perfect for the trailer).
Old June 24th 20, 04:18 AM posted to rec.aviation.soaring
Bret Hess
The HC-2500 Amerflint II polyurethane is 2K. You mix in the hardener. It's called "Single stage" which means its gloss comes with a single application (no clearcoat needed).
Old June 23rd 20, 08:36 AM posted to rec.aviation.soaring
I used Lesonal 540 2K primer. Great stuff, not cheap but the base coating is really good.
Available in Europe, from AKZO I believe.
Next step is to finish the final layer in gloss white.
Ronald de Vries
Old June 23rd 20, 08:45 AM posted to rec.aviation.soaring
Senna Van den Bosch
Ronald de Vries
Is it the 2K filler 540 white? I found this on a Dutch website, pricing seems about the same (€ 75 for 3 liters) as others for 0.75-1 liter.
What would you finish it with and how many layers of the 2K primer would you use?
Old June 23rd 20, 12:07 PM posted to rec.aviation.soaring
Lesonal 540 2k primer/filler is white with a yellowish tint, but not grey and not flashing white.
When you finish with a topcoat glossy white you will not see this.
I applied with a roller and did one coating, a bit thick. You can also do two coatings but more thin.
Regards,
Ronald de Vries
Cobra trailer aluminum vs fiberglass top 2G Soaring 31 July 20th 18 03:32 AM
Foam for inside of fiberglass trailer John[_27_] Soaring 9 April 4th 13 04:12 AM
Painting fiberglass Cobra trailer [email protected] Soaring 12 January 19th 13 02:23 AM
Touch Up White Paint O. Sami Saydjari Owning 10 May 29th 05 11:58 PM
Painting a Fiberglass Trailer Experiences ContestID67 Soaring 4 April 28th 05 07:40 PM
