Paint for white fiberglass trailer top
Old June 23rd 20, 11:14 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
Quote:
Originally Posted by Senna Van den Bosch View Post
Op dinsdag 23 juni 2020 02:43:12 UTC+2 schreef Delta8:
I refinished a Komet trailer 3 yrs ago with Boat paint . Self leveled
and didn't see any roller marks afterwards. Came out great, UV
protection as well although about $50.00 a Qt. I sanded first with an
orbital sander 150 and used 5 coats .
Very good coverage for a qt.
Also afterwards I used a white roofing silicone along the galvanized
base .
http://tinyurl.com/yaudtp3z
Delta8
What's a Qt if I may ask? Or is that in liters? (I'm from EU)
Quart
https://www.google.com/search?q=quar...hrome&ie=UTF-8
Old June 24th 20, 04:08 AM posted to rec.aviation.soaring
Bret Hess
Default Paint for white fiberglass trailer top
I painted my trailer with HC-2500 Amerflint II polyurethane from Tamco paint. It's been in sun and snow year around for 3 years and still looks like it did the day I painted it. It's excellent...I'm painting my glider with it this month.
https://tamcopaint.com/products/dura...30875014496336 . You have to wear a passive carbon filter mask that traps organics while spraying, but it's no big deal.
Excellent customer service, too.
Old June 24th 20, 04:12 AM posted to rec.aviation.soaring
Bret Hess
For primer I used https://www.homedepot.com/p/Rust-Ole...0502/100126115 . I thinned it with urethane thinner and it worked great. Very tough stuff. (On my glider I'll use a urethane 2K primer, but this is perfect for the trailer).
Old June 24th 20, 04:18 AM posted to rec.aviation.soaring
Bret Hess
The HC-2500 Amerflint II polyurethane is 2K. You mix in the hardener. It's called "Single stage" which means its gloss comes with a single application (no clearcoat needed).
Cobra trailer aluminum vs fiberglass top 2G Soaring 31 July 20th 18 03:32 AM
Foam for inside of fiberglass trailer John[_27_] Soaring 9 April 4th 13 04:12 AM
Painting fiberglass Cobra trailer [email protected] Soaring 12 January 19th 13 02:23 AM
Touch Up White Paint O. Sami Saydjari Owning 10 May 29th 05 11:58 PM
Painting a Fiberglass Trailer Experiences ContestID67 Soaring 4 April 28th 05 07:40 PM
