Paint for white fiberglass trailer top
Old June 24th 20, 04:12 AM posted to rec.aviation.soaring
Bret Hess
Default Paint for white fiberglass trailer top
On Tuesday, June 23, 2020 at 9:08:16 PM UTC-6, Bret Hess wrote:
I painted my trailer with HC-2500 Amerflint II polyurethane from Tamco paint.
For primer I used https://www.homedepot.com/p/Rust-Ole...0502/100126115 . I thinned it with urethane thinner and it worked great. Very tough stuff. (On my glider I'll use a urethane 2K primer, but this is perfect for the trailer).
Old June 24th 20, 04:18 AM posted to rec.aviation.soaring
Bret Hess
The HC-2500 Amerflint II polyurethane is 2K. You mix in the hardener. It's called "Single stage" which means its gloss comes with a single application (no clearcoat needed).
Cobra trailer aluminum vs fiberglass top 2G Soaring 31 July 20th 18 03:32 AM
Foam for inside of fiberglass trailer John[_27_] Soaring 9 April 4th 13 04:12 AM
Painting fiberglass Cobra trailer [email protected] Soaring 12 January 19th 13 02:23 AM
Touch Up White Paint O. Sami Saydjari Owning 10 May 29th 05 11:58 PM
Painting a Fiberglass Trailer Experiences ContestID67 Soaring 4 April 28th 05 07:40 PM
