There is no difference between mild steel and 4130 as far as corrosion
resistance is concerned, Now you have got my curiosity in gear. As I said, my personal experience is that I have seen a significant differance. I went looking for some quantized data on the subject. I have not found what I was looking for on the net, and may run up to the University library later on. For now I found http://www.armycorrosion.com/summit2...PM/schario.pdf It does not have much in the way of quantized data, comparing 1010 to 4130 corrosion properties, but there is enough to refute the claim that there is no differance. Anybody got a link that does a better job with this? |
Ron Webb wrote:
There is no difference between mild steel and 4130 as far as corrosion resistance is concerned, Now you have got my curiosity in gear. As I said, my personal experience is that I have seen a significant differance. I went looking for some quantized data on the subject. I have not found what I was looking for on the net, and may run up to the University library later on. For now I found http://www.armycorrosion. com/summit2001/DAY_1_PM/schario.pdf It does not have much in the way of quantized data, comparing 1010 to 4130 corrosion properties, but there is enough to refute the claim that there is no differance. The stuff in my garage doesn't seem to notice any difference. It is more than happy to rust if I don't do anything to protect it. It could be that it happens slower; I haven't done any sort of scientific testing to see. But the bottom line is that rusty is rusty. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Agreed...but if it took 30 years to rust out the back of the longerons on your new float equipped Bearhawk to the point of them being unsafe, since they are .049" 4130 - but it would take 100 years to do the same thing to ..063 1010 --that might be enough to tip the scales if the weight differance was 20 pounds or so... OK, I'll admit it...I made the longerons on my MoHawk out of 1/2 x.032 4130 too, just like the plans say...but there are MANY things I'd do differently if I was starting over...like start with a set of Bearhawk plans for instance;^} |
In Ron Webb wrote:
Agreed...but if it took 30 years to rust out the back of the longerons on your new float equipped Bearhawk to the point of them being unsafe, since they are .049" 4130 - but it would take 100 years to do the same thing to ..063 1010 --that might be enough to tip the scales if the weight differance was 20 pounds or so... My position is that if the lower longerons are getting rusty, there are other parts in there that I need to be just as concerned about. Beefing up parts doesn't make the airframe any stronger necessarily, it only shifts the weak point elsewhere. I would expect that to be true of corrosion issues as well as overall strength. I would rather go the extra mile with corrosion protection measures NOW while the plane is under construction, than add a bunch of unneeded weight by making everything thicker. In 20-30 years I will most likely want to tear the fabric off and inspect everything closely no matter what anyway. I've got a sandblaster and I'm not afraid to use it. OK, I'll admit it...I made the longerons on my MoHawk out of 1/2 x. 032 4130 too, just like the plans say...but there are MANY things I'd do differently if I was starting over...like start with a set of Bearhawk plans for instance;^} I hear that a lot. 8^) ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
A building material that is less expensive and more available may in
practice end up building a lighter airframe. The reason is that you're more likely to be able to use the exact right stock instead of just over building because you couldn't find or afford the expense to buy a special piece of the lighter guage material. Bend versus break. Old cars were build on rigid chassis, the safety argument was that you want something really strong. But modern cars are generally built uni-body designated crush zones to dissipate some of the energy instead of transfering it to the passengers. "In theory, practice and theory are the same. But in practice, they are often very different." |
In Jay wrote:
A building material that is less expensive and more available may in practice end up building a lighter airframe. The reason is that you're more likely to be able to use the exact right stock instead of just over building because you couldn't find or afford the expense to buy a special piece of the lighter guage material. Speak for yourself. If my plans call for a specific material, that is what I use. On the couple of occasions where I have deviated, I placed long distance calls to the designer to get his okay on the changes. Bend versus break. Old cars were build on rigid chassis, the safety argument was that you want something really strong. But modern cars are generally built uni-body designated crush zones to dissipate some of the energy instead of transfering it to the passengers. I'm all in favor of less rigidly constructed car chassis for other people. That way, when I get into a collision with one of them, they will serve as a crush zone for my rigid chassis and heavy duty bumpers. If I get into an accident where (for example) my '73 pickup truck isn't sufficient to protect me, chances are I wouldn't want to survive that anyway. Not to say I won't try to improve my chances where it makes sense; I just finished fabricating a set of brackets to convert the old beast from lap belts only to lap with shoulder belts. "In theory, practice and theory are the same. But in practice, they are often very different." "No plan survives contact with the enemy intact." ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Driving sheet-metal screws into 4130 | Grandpa B. | Home Built | 10 | February 3rd 04 07:23 PM |
4130 Chromaloy Sheet Availability | c hinds | Home Built | 1 | January 24th 04 04:17 AM |
Tube Cluster Weld Question | Dick | Home Built | 6 | January 17th 04 12:10 AM |
Pitts Special Steel Tube Fuse Mod. | Martin Morgan | Home Built | 0 | November 23rd 03 11:08 PM |
4130 frame? | Steve Thomas | Home Built | 23 | August 27th 03 05:50 PM |
