Alternate static on "big iron"?
  #11
Old April 23rd 04, 02:06 PM
tom418
On the B727, the Captain's or F/O's static sources are selectable from
Normal to "Alternate", which would provide the static instruments with
static air which is used for the Mach Airspeed Warning and Pressurization
systems
"Marc Lattoni" wrote in message
news:c3%hc.1386$2q2.192@edtnps84...
Last night on Discovery Channel there was a story of a Peruvian 757 that
went down because the two static ports had been taped over for cleaning
and
not removed. As you might imagine, the airspeed indicator and altimeter
gave
erroneous readings and fed the onboard computers erroneous data; after a
series of bizarre warning messages (zero airspeed and "over speed warning"
from the computer) the pilots attempted to correct for contradictory
information and multiple warnings and the plane crashed into the ocean
Do modern airliners not have an alternate static source as on my 172?
Marc
Is my static port leaking? Derrick Early Instrument Flight Rules 2 August 15th 04 01:13 AM
What caused the VSI and ALT bouce in the IMC? cpu Instrument Flight Rules 38 May 5th 04 03:45 PM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Why a static port? Paul Mennen Owning 11 August 19th 03 04:58 AM
Static in KX-165A Chad Lemmen Owning 3 July 21st 03 09:57 PM
