"Marc Lattoni" wrote in message news:c3%hc.1386$2q2.192@edtnps84...
Do modern airliners not have an alternate static source as on my 172? They have alternate static, but it's not as simple as the one on your 172. If yours is like most spamcan alternate static sources, it opens the static system to the cabin air. Simple and almost foolproof, but that sort of system wouldn't work on a pressurized airplane. The artificially high cabin pressure would generate erroneous readings. A pressurized airplane would have to have its alternate static source open to the outside air (where it can be taped over). John Galban=====N4BQ (PA28-180) |
Is my static port leaking? | Derrick Early | Instrument Flight Rules | 2 | August 15th 04 01:13 AM |
What caused the VSI and ALT bouce in the IMC? | cpu | Instrument Flight Rules | 38 | May 5th 04 03:45 PM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Why a static port? | Paul Mennen | Owning | 11 | August 19th 03 04:58 AM |
Static in KX-165A | Chad Lemmen | Owning | 3 | July 21st 03 09:57 PM |
