SSA petition to allow transponder to be turned off
Old February 22nd 04, 01:31 AM
Ian Cant
This appeared out of the blue, at least to me. If
approved as it stands, it certainly would be an encouragement
to install a transponder. But what is the SSA's position
if the FAA comes back at some future date and says
'Yes, but now that you have pointed out that battery-operated
transponders are available, there is no reason why
ALL non-electric aircraft should not be REQUIRED to
have a transponder installed' ? Like the part 103
ultralights, maybe it is best not to tamper with an
existing favorable exemption.
Ian
At 18:48 21 February 2004, Eric Greenwell wrote:
Check out the SSA website for the complete info on
this petition, and
consider commenting to the FAA (comments due by March
1, via web site,
mail, fax, 'eRulemaking portal'):
SSA Transponder Petition Published
By Dennis Wright
Posted Thursday, February 19, 2004
The SSA petition asks that SSA members be allowed to
operate
transponder-equipped gliders with the transponders
turned off, when the
glider is being operated more than 40 nautical miles
from the primary
airport in Class B airspace and more than 20 nautical
miles from the
primary airport in Class C airspace. Currently, Federal
Aviation
Regulation 91.215[c] requires that all aircraft equipped
with a
transponder and operating in controlled airspace have
the transponder on.
....more on the web site
change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
transponder codes Guy Elden Jr. Piloting 1 December 2nd 03 05:21 PM
