Thanks for the comments. I looked through both the DG-100 and DG-100G
(which I own) manuals and found nothing about the static port usage. In fact I found nothing concerning ANY of the air lines within the ship. Could I ask you to look through your manual and see if you can find the reference? Thanks, John Nick Hill wrote in message ... John DeRosa Sky Soaring Chicago IL wrote: I need you opinion on which static ports to use on the DG. The friendly folks at Glaser-Dirks provided me with two pairs of static ports on my DG. snip So which to use? Look in the manual for the aircraft. I have a DG 100 and if I remember correctly it states use the forward pair for ASI and the rearward pair for soaring instruments. Nick Hill |
Is my static port leaking? | Derrick Early | Instrument Flight Rules | 2 | August 15th 04 01:13 AM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
The Great Static Wick Fraud | Craig Prouse | Owning | 3 | September 5th 03 01:54 AM |
Why a static port? | Paul Mennen | Owning | 11 | August 19th 03 04:58 AM |
Static in KX-165A | Chad Lemmen | Owning | 3 | July 21st 03 09:57 PM |
