"arthur mcallister" wrote in news:CbrQd.218052
: Why would anyone time a hold in this day and age? For checkride purposes. That's the only reason I can think of. For my ATP ride, I had to time the hold and make the inbound leg one minute. In the real world, I would never bother. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
To make sure that it remains part of your habits. One day you'll fly an airplane without GPS, or the box will go TU, or for any number of reasons you won't be able to rely on it. Stay in practice and you'll be ok. Jose |
On Tue, 15 Feb 2005 21:21:32 GMT, Jose
wrote: Why would anyone time a hold in this day and age? To make sure that it remains part of your habits. One day you'll fly an airplane without GPS, or the box will go TU, or for any number of reasons you won't be able to rely on it. Stay in practice and you'll be ok. Jose I have to practice starting a stopwatch? |
No, one should practice =remembering= to start a stopwatch. Jose |
Jose wrote:
I have to practice starting a stopwatch? No, one should practice =remembering= to start a stopwatch. Actually, with some of the brain-damaged UI's some digital watches have, you really do need to practice starting it. I actually prefer a plain sweep second hand clock in the panel (one of those good-old 8-day windup things work just fine). Glance at the thing when you start outbound, when the second hand gets back to the same place, turn inbound. Correct as required for wind. |
"Roy Smith" wrote in message
... I actually prefer a plain sweep second hand clock in the panel (one of those good-old 8-day windup things work just fine). Glance at the thing when you start outbound, when the second hand gets back to the same place, turn inbound. Correct as required for wind. Same here. In our old club PA-28 the clock was never, ever right because the knob you set it with had long since fallen off. The second hand worked fine, though, so when you went overhead the beacon you simply remembered what number the second hand was pointing at and waited for it to point that way again. In our current aircraft, the clock is generally right. Same principle holds, though :-) D. |
![]() "arthur mcallister" wrote in message ... Why would anyone time a hold in this day and age? June 14, 1998 Pelican's Perch #5: Don't Time That ILS Approach! http://www.avweb.com/news/columns/182042-1.html "...if you start a NON-precision approach (including a LOC-only) and fail to start the timer (or note the time), it's a major boo-boo. Your only recourse is to immediately go missed and start it over. If you perform an approach where timing is required, and you do not time it, it's a good bust on a checkride, for that is compounding an error with stupidity." -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Approach Timing | john smith | Instrument Flight Rules | 36 | September 9th 04 03:37 PM |
Timing light for electronic ignition | Ron | Home Built | 4 | August 20th 04 05:18 PM |
internal timing of slick magneto | Jerry Jensen | Home Built | 1 | June 25th 04 07:59 PM |
Holds for currency requirements | Paul Tomblin | Instrument Flight Rules | 8 | March 12th 04 06:49 PM |
Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 10:08 PM |
