![]() "Jay Honeck" wrote in message news:t_y0e.101078$Ze3.47168@attbi_s51... All and all, not a bad day -- but too much salt and fat. Still, I just finished 30 minutes of lifting with my son, so hopefully I've offset some of it! -- Hmmm, This needs a thread between anaerobic and aerobic exercises. First off, any time the calorie output exceeds the calorie input the result is a net loss in weight -- regardless of the type of exercise. So much for that. But the real answer to exercising to improve the cardiovascular system lies in aerobic exercise. A minimum aerobic workout would be something equivalent to walking at a pace that pushes your heart rate up to your individual training range and sustaining that pulse rate for at least 20 minutes, followed by a gradual cool-down to prevent cramping. The published minimum is three times a week, although I hear rumors that both duration and frequency are being increased by the pundits. In any case, start out at the minimums and increase gradually. What I discovered was that, as I began to improve, I had to work harder and longer just to get the pulse rate into the training range. I can't run because of a hip problem so I had to keep extending the times, that works also. You can do the same thing indoors with treadmills, stationary bikes, elliptical trainers, stairstepper, etc., when the weather doesn't permit. Personally, I like to see the sky and smell the flowers so I'm outside whenever I can. Anaerobic, free-weights, Nautilus, etc., are great for muscle development. I do 3 days aerobic alternating with 2 days anaerobic. I'm on a BP med and my doc just cut the dose in half. My BP, typically, is 110/60, now. In any case, DO NOT rely on exercise alone to improve your CV status. Over a period of time, calories out has to exceed calories in if you are going to reduce the weight. I'll bet though, that weight isn't your problem, not working as an inn-keeper. |
High thrust line on canard design? | Shin Gou | Home Built | 4 | March 5th 05 03:06 AM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 7 | November 6th 04 08:34 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
Vacuum pressure | Peter MacPherson | Instrument Flight Rules | 1 | May 30th 04 04:01 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
