ATC Altimeter Settings
Old April 4th 05, 02:47 AM
Newps
John R. Copeland wrote:
Chip, you didn't mention enroute altimeter settings being different from surface ones.
I've seen that condition in the Rocky Mountains, but I can't specifically recall
if I've ever seen it in the central and eastern U.S.
Controllers issue altimeter settings from ground stations. Where else
would they come from?
Old April 4th 05, 02:50 AM
Roy Smith
surface ones.
recall
You get them off DUATS like the rest of us?
Old April 4th 05, 03:12 PM
Newps
surface ones.
recall
Yes, and they come from ground stations. There are no special enroute
airborne stations in the mountains.
Old April 4th 05, 03:47 PM
I fail to see what the usefulness would be.
As long as everyone is flying with the same lapse rate error, who
cares?
On Mon, 04 Apr 2005 08:12:04 -0600, Newps wrote:
surface ones.
recall
Old April 4th 05, 03:53 PM
John R. Copeland
"Newps" wrote in message =
=20
=20
Roy Smith wrote:
Newps wrote:
=20
=20
Chip, you didn't mention enroute altimeter settings being different =
from=20
surface ones.
I've seen that condition in the Rocky Mountains, but I can't =
specifically=20
recall
Controllers issue altimeter settings from ground stations. Where =
else=20
=20
=20
=20
Yes, and they come from ground stations. There are no special enroute =
In the Rockies, there are ground stations at widely varying elevations.
I've guessed that ATC might not use settings from airports in deep =
valleys
for enroute settings, wherever more representative values are available.
The terminology I've heard used at specific locations is something like:
"XXX altimeter nn.nn, Area altimeter nn.mm."
I don't really know how the "Area" numbers are established,
but I'd certainly want to use the local airport setting for landings.
Old April 4th 05, 04:08 PM
Steven P. McNicoll
"John R. Copeland" wrote in message
I've guessed that ATC might not use settings from airports in deep valleys
Where did you hear "area altimeter nn.nn"?
Old April 4th 05, 04:26 PM
Matt Barrow
How would a station be more representative if it was/wasn't in a valley or
on a hill top?
  #28
John R. Copeland
"Steven P. McNicoll" wrote in message =
. net...
=20
"John R. Copeland" wrote in message=20
In the Rockies, there are ground stations at widely varying =
elevations.
valleys
for enroute settings, wherever more representative values are =
available.
The terminology I've heard used at specific locations is something =
like:
=20
One place I recall specifically was KBCE.
  #29
Old April 4th 05, 04:32 PM
John R. Copeland
"Matt Barrow" wrote in message =
=20
=20
elevations.
valleys
available.
=20
How would a station be more representative if it was/wasn't in a =
valley or
on a hill top?
=20
In the case of non-standard lapse rates, the lower the airport,
the more the altimeter differs from true height across mountain peaks.
  #30
Old April 4th 05, 04:43 PM
Newps
Lapse rate is temp and has little effect on the altimeter setting.
Because you are already separated from the ground by 2000 feet it is
much more important that everybody have the same setting. No such thing
as an area altimeter setting.
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
Altimeter experience HankC Piloting 2 July 25th 03 09:43 PM
