Pressure Washer
Old April 30th 05, 04:16 AM
Dave S
Mike W. wrote:
That's fine. The idea is to get enough water flow from your tank to feed the
pump. Like another poster said, with inadequate water flow it will cavitate
and the sprayer will start burping out air.
The reason they tell you a minimum of 20psi is they figure worst case,
somebody will hook it up with a 1/2" garden hose. So in order for that hose
to deliver water at a useable rate, you need around 20psi.
Especially if say, you were feeding that flow rate though 100 feet of
1/2" hose. The flow losses are directly related to the distance.
Dave
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 05:49 PM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 08:35 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
