stephanevdv wrote:
Just as efficient (or inefficient), and decimal, but it hasn’t been able to replace the 360 degree system, Just to add confusion to the discussion: The decimal system has been about the dumbest idea which has happened to mankind. The phoenicians got it right by using the duodecimal system (actually, they used even the 60-system), which is much more suited for most real life situations. But some dimmer folks replaced it by the decimal system, because they couldn't do the math without using their fingers. So I fear we have to live with that. Stefan |
'duodecimal system' -- We use that all the time in libraries in the
USA. Larry "Stefan" wrote in message : stephanevdv wrote: Just as efficient (or inefficient), and decimal, but it hasn't been able to replace the 360 degree system, Just to add confusion to the discussion: The decimal system has been about the dumbest idea which has happened to mankind. The phoenicians got it right by using the duodecimal system (actually, they used even the 60-system), which is much more suited for most real life situations. But some dimmer folks replaced it by the decimal system, because they couldn't do the math without using their fingers. So I fear we have to live with that. Stefan |
01-- Zero One wrote:
'duodecimal system' -- We use that all the time in libraries in the USA. Groan :-). Tony V. |
Altimeter settings: QNH versus QFE | [email protected] | Soaring | 28 | June 6th 05 12:26 PM |
Reading back altimeter settings? | Paul Tomblin | Piloting | 31 | April 12th 05 04:53 PM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
Local altimeter at BFM | Dan Luke | Instrument Flight Rules | 3 | June 15th 04 02:01 PM |
