![]() "Gordon Arnaut" wrote One of the biggest dangers in using wood as a structural material is compression failures that are almost invisible to the naked eye. A piece of wood that has been severely stressed (such as sitting under some big heavy boxes on the UPS truck) may look perfectly good, but its fibers may be have completely lost their strength. ???????????????????????????????????/ You HAVE to be totally kidding. Unless that wood was sitting under a 10,000 lbs box on the UPS truck, it WILL NOT get compressive failure like that. Most compressive fractures take place when the tree is felled, and lands across a swag, or on another log. You had a pretty good writing going, but you lost all credibility, with that last line of crap. Also, rupture is not the only mode of failure that is important. You have to know if the part you are replacing is in tension, compression, bending, or what. There are different values for each mode. -- Jim in NC |
Do you have some sort of personality disorder?
If you disagree with something I said, then address it in civil terms as I have done when I disagreed with the other poster's point. There is no excusable reason to launch into a personal attack and what I wrote "crap." I would address your objections, but I don't argue with people who don't adhere to basic civility. You are obviously an odiferous idiot and as such I will ignore your stupid outburst. Gordon Arnaut. "Morgans" wrote in message ... "Gordon Arnaut" wrote One of the biggest dangers in using wood as a structural material is compression failures that are almost invisible to the naked eye. A piece of wood that has been severely stressed (such as sitting under some big heavy boxes on the UPS truck) may look perfectly good, but its fibers may be have completely lost their strength. ???????????????????????????????????/ You HAVE to be totally kidding. Unless that wood was sitting under a 10,000 lbs box on the UPS truck, it WILL NOT get compressive failure like that. Most compressive fractures take place when the tree is felled, and lands across a swag, or on another log. You had a pretty good writing going, but you lost all credibility, with that last line of crap. Also, rupture is not the only mode of failure that is important. You have to know if the part you are replacing is in tension, compression, bending, or what. There are different values for each mode. -- Jim in NC |
![]() "Gordon Arnaut" wrote If you disagree with something I said, then address it in civil terms as I have done when I disagreed with the other poster's point. There is no excusable reason to launch into a personal attack and what I wrote "crap." I am normally a _very_ civil person, but I go off the deep end when someone makes a post retorting to have a command of subject matter, then displays an utter *lack* of grasp on the subject. People who know no better might believe you, and commit a design change/substitution that kills them. this is big stuff, with life ending possibilities. In order to have a compression fracture to take place, the wood has to be compressed past the ultimate failure of the species, in compression, or if it were bent, in rupture on the side of the board that is in the "low" side of the bend. How much force would be required would then depend on the specifics of the size of the stock. I would dare to say, that the loads required would be HUGE; it would be enough to crush the floor, and suspension, and blow the tires of a UPS truck, if it were say, a spar, of unremarkable size. That is not going to happen from having a box, or boxes, or even a V-8 engine sitting on it. How ridiculous! If you purport to write as an expert, dispensing advise, you must be prepared to take your lumps when you blow it. You blew it. Oh, by the way, pot, kettle, black. You seemed to do a pretty good job of not addressing me in a civil manner. I do not have a personality disorder, nor am I odiferous, nor am I an idiot. I was, however, bold enough to call you bluff on a subject you should not be writing about, if you are so far off base from knowing the basic causes of this kind of failure in wood. It seriously makes me wonder how far off base you are on the rest of the figures and concepts you wrote about. I might suggest that other readers also view the previous posts made by you with a *very* large grain of salt. Civil enough? If not, tough. Live with it. -- Jim in NC |
Morgans wrote:
In order to have a compression fracture to take place, the wood has to be compressed past the ultimate failure of the species, in compression, or if it were bent, in rupture on the side of the board that is in the "low" side of the bend. How much force would be required would then depend on the specifics of the size of the stock. I would dare to say, that the loads required would be HUGE; it would be enough to crush the floor, and suspension, and blow the tires of a UPS truck, if it were say, a spar, of unremarkable size. That is not going to happen from having a box, or boxes, or even a V-8 engine sitting on it. How ridiculous! Hey, Jim, I'm not trying to be odiferous (whatever that may be), I'd just really like to know. Does it make a difference that they UPS truck will bring the wood in strips that are much smaller than a forest log? That is, will it stand more of possibility from damage in the cut and cured state? Another factor...an object doesn't have to weigh 10,000lbs to apply 10,000psi of force. If the wood ends up supporting another object by an edge or a corner (or even a point), and the truck hits a bump, 10,000psi might not be so extreme. A somewhat strained example: someone traps a coat hanger between the sitka bundle and a V-8 engine place on top. My sister-in-law got a new hardwood floor installed (I sweated a lot putting that one in), and started to set little round indentations in it. She was livid, blaming it on husband and children, started to call Home Depot and give them what-for. Luckily, I stopped her in time and pointed out her spiked high-heels. Lot of pressure there from a one-hundred and ????? pound woman. I guess that's all just to say, "Don't trust the UPS man." I used to work a dock. I've seen the forklifts used to help a load 'fit' in the truck. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
![]() "Ernest Christley" wrote Hey, Jim, I'm not trying to be odiferous (whatever that may be), I'd just really like to know. Thanks for that. I think that *might* be something like stinking, g and I haven't been close enough to smell you! I'll attempt to shed some light on your (and others) concerns. I don't pretend to know everything about wood, but I have studied the forrest products book, (good stuff) and others on wood AC, and have been around wood (carpenter, cabinet maker, jack of all trades) all my life. Does it make a difference that they UPS truck will bring the wood in strips that are much smaller than a forest log? Sure, the smaller the piece, and the longer, the less abuse it can stand. Still, the most common way (by a million percent) of compressive fractures occur while the wood is in the shape of a log. That is, will it stand more of possibility from damage in the cut and cured state? Actually, wood is stronger in it's dry state. Much stronger. Milled, yes, it will be weaker than a log, but only because it is not as large. Another factor...an object doesn't have to weigh 10,000lbs to apply 10,000psi of force. True, you can generate more than the rated force without the rated weight. or force. The good old principle of the lever at work, (and mechanical advantage) is our main concern. If the wood ends up supporting another object by an edge or a corner (or even a point), and the truck hits a bump, 10,000psi might not be so extreme. Humm, this might be possible, but there are other things to consider to make this a problem. First, remember, we are talking (P)ounds per (S)quare (I)nch. Most of the stuff we are going to order are much larger than a square (cross sectional) inch, thus it will take much more force to be of concern. Lots of calculations - moments of inertia, leverage, compression, buckling loads, bending- all much more ugly than I want to go into here. Lets go for broad concepts, and rough figures. If the board were supported by a corner, on what is the corner resting on. A shelf? Shelf gets crusted, if the board is of any size. Remember UPS has a maximum weight, as I recall, about eighty some pounds. It will be necessary to have many of these boxes to add up to enough to hurt anything, except little sticks. A point, say a rock under the plank? Part of the weight dents the floor or crushes the rock, (UPS drivers are not in the habit of hauling around a truck full of gravel) and part of the point load puts a big dent in the board. This is still not a compressive failure. A compressive failure is a _line_ of ruptured cells, and hard to see; not what is happening here. It would make that one point as weak as say, a knot. Easy to detect, so although the board may be damaged, it is easy to see. Report the damage, get a new plank, or work (cut it out) to eliminate the damage. That is done all of the time, to eliminate less that acceptable parts (defects) in the lumber. A extreme weight like an engine would not be resting on a sharp point, like a flange sitting on the plank. It would be on a pallet, thus spreading the load. Also, UPS does not ship engines; that would be some type of motor freight. Another point to consider is that in order to reach the point of rupture, the board is going to bend a HUGE amount before _any_ damage is done. A somewhat strained example: someone traps a coat hanger between the sitka bundle and a V-8 engine placed on top. Not likely, but once again, the damage would be a dent, not a compressive failure; at least not anything but a highly localized event. Easy to spot, so mill it out, or reject it. My sister-in-law got a new hardwood floor installed (I sweated a lot putting that one in), and started to set little round indentations in it. She was livid, blaming it on husband and children, started to call Home Depot and give them what- for. Luckily, I stopped her in time and pointed out her spiked high-heels. Lot of pressure there from a one-hundred and ????? pound woman. Wow, want to talk extreem pressure, huh? g Yep, high heels are hell on wood floors. It is easy for a petite woman to put well over 1,000 pounds per square inch on a floor. Still easy to see; take action to remove or eliminate the problem... (on the floor, not the woman g) I guess that's all just to say, "Don't trust the UPS man." I used to work a dock. I've seen the forklifts used to help a load 'fit' in the truck. All easy to see problems. It would be more likely to have the compressive fracture we are concerned about happen by taking a 1 inch by 8 inch board supported by raised fulcrums say, 4 feet across, then use the board as a ramp for the forklift to drive across. (like a bridge) That would be unusual treatment for even a loading dock, and I believe you would agree. Wood is a wonderful material. It is flexible, but strong. It can take a surprising amount of abuse, and spring back, with no damage. After the big Japanese earthquake, (what, 15 years ago?) the Japanese sent teams of engineers to further study our wood frame house building practices, because their mostly steel residential construction methods did not flex, but buckle. That (in house construction) is a case of much lower grade lumber. (than aircraft lumber) You should see what lumber wholesalers are passing off for #2 grade lumber, nowadays. Also, houses are nailed together, not fastened with epoxy and scarf joints, like in aircraft practices. In conclusion, don't worry about airplane lumber getting damaged by UPS. Large stuff would have to have the whole truck run over it. Smaller stuff will bend, long before the driver realizes that his loading is a problem, and if it is firmly bundled, the whole bundle will share the load. If you are building a wood aircraft, you should be trained in recognizing defects, eliminating them, and safely orienting, joining and using wood. Your life is on the line, and you better know what you are doing. There are many things to worry about, (including substituting species) but damage from the UPS man delivering your wood should be about 273rd on your list. g -- Jim in NC |
I'm posting this for the normal people in this group who might thing that
this "Morgans" clown actually has some kind of valid point. His remarks make quite clear that he doesn't know the first thing about structures. Yet he comes out with guns blazing and hurling unprovoked insults. What a clown. For example, take his comment about modulus of rupture not being relevant to stress in compression or tension. This is complete gibberish that shows he doesn't understand even the basics. Modulus of rupture is a measure of a material's strength in bending. Bending loads on a piece of wood (or other material) typically produce stress in both compression and tension at the same time. Take a wood yardstick and hold it by the ends; now try to bend it into a U shape. The wood fibers on the inside of the curve will be in compression, while those on the outside will be in tension, simultaneously. If you apply enough bending moment you can break the stick. But what if you bend it as far as you can without breaking it and then let it go? Have you done any damage? It's quite possible tthat you have damaged the wood fibers that were in compression (the top of the stick). Almost certainly you will not have damaged the bottom of the stick, which was under tension. The reason is that wood is about two to three times stronger in tension than in compression. So while you didn't break the stick, you might have caused compression failure on the side of the stick that was on the inside of the curve. This damage would be most acute on the top surface of the stick and would be progressivly less until the neutral axis (middle) of the stick. If you made a saw cut right across the point of bending, you would probably see -- under a magnifying glass -- wood fibers that have failed in compression. If you have ever broken small pieces of wood in half with your hands you would have experienced this first hand. If you take that yardstick and bend it until it starts to break, what happens? It does not just snap at once. The outside part that is under tension will begin to splinter long before it lets go. Then in order to break it, you instinctively bend it back in the opposite direction and what happens? It makes a clean break on the top surface -- the surface that was under compression -- while the bottom surface continues to splinter. This shows you just how much stronger the wood is in tension than in compression. So even bending the stick and letting go befoer it breaks could have caused compression failure on the top surface. The next time you bend that stick in the opposite direction, there will be no strength in the top part -- it will just let go. That's exactly how sticks of wood can get damaged in transit. All it takes is bending the stick enough to cause compression on the inside of the bend. And you would never know by merely looking at it. Idiot's comments about needing 10,000 pounds on top of the wood simply illustrate to everyone what a loudmouth know-nothing he is. All it takes is enough force to bend the plank more than you would normally do. This does not have to be a lot of force. We are talking about small planks less than an inch thick. You could easily cause compression failure on small sticks of wood like this just by bending it forcefully with your bare hands. Is that the kind of massive pressure idiot is talking about? The fact is that this type of damage can and does happen in shipment. It is quite easy as my explanation should make clear. All that needs to happen is for the board to be bent awkwardkly -- and this does not take a whole lot of weight. A couple of humdred pounds acting on the end of a plank could be enough to do it. As to his other objection about modulus of rupture not being "enough" of a measure to determine wood substitution, this is simply not true. This is the most important measure of strength. Fbu (sometimes referred as jut Fu) is the ultimate stress before failure in bending. There are also measurements for stiffness, elasticity, strength in compression and tension both paralell and perpendicular to the grain and a few more. But the undisputed fact is that for structural members, Fbu is the most important measurement. If the substitute wood passes muster in this measurement, then it will pass in all the others -- since these strength properties all tend to vary proportionately across species. For example if pine is 15 percent weaker in bending than spruce, it is also weaker by a similar amount in the other strength measures. In closing, I really have to register my utmost contempt at this pathetic clown for the way in which he is conducting his attacks. He obviously knows nothing, yet he has the brass to call into question factual material I have presented which is 100 percent valid. I challenge this complete moron to point out one mistake in the methodology or math I have presented. I will bet dollars to donuts that he won't even attempt it -- he wouldn't know where to start. Regards to All (Except to Moron in NC) Gordon Arnaut. "Morgans" wrote in message ... "Gordon Arnaut" wrote If you disagree with something I said, then address it in civil terms as I have done when I disagreed with the other poster's point. There is no excusable reason to launch into a personal attack and what I wrote "crap." I am normally a _very_ civil person, but I go off the deep end when someone makes a post retorting to have a command of subject matter, then displays an utter *lack* of grasp on the subject. People who know no better might believe you, and commit a design change/substitution that kills them. this is big stuff, with life ending possibilities. In order to have a compression fracture to take place, the wood has to be compressed past the ultimate failure of the species, in compression, or if it were bent, in rupture on the side of the board that is in the "low" side of the bend. How much force would be required would then depend on the specifics of the size of the stock. I would dare to say, that the loads required would be HUGE; it would be enough to crush the floor, and suspension, and blow the tires of a UPS truck, if it were say, a spar, of unremarkable size. That is not going to happen from having a box, or boxes, or even a V-8 engine sitting on it. How ridiculous! If you purport to write as an expert, dispensing advise, you must be prepared to take your lumps when you blow it. You blew it. Oh, by the way, pot, kettle, black. You seemed to do a pretty good job of not addressing me in a civil manner. I do not have a personality disorder, nor am I odiferous, nor am I an idiot. I was, however, bold enough to call you bluff on a subject you should not be writing about, if you are so far off base from knowing the basic causes of this kind of failure in wood. It seriously makes me wonder how far off base you are on the rest of the figures and concepts you wrote about. I might suggest that other readers also view the previous posts made by you with a *very* large grain of salt. Civil enough? If not, tough. Live with it. -- Jim in NC |
![]() "Gordon Arnaut" wrote I'm posting this for the normal people in this group who might thing that this "Morgans" clown actually has some kind of valid point. OK, I tried nice, but you don't want to play, so first of all, a general, FYT. His remarks make quite clear that he doesn't know the first thing about structures. Yet he comes out with guns blazing and hurling unprovoked insults. What a clown. For example, take his comment about modulus of rupture not being relevant to stress in compression or tension. In contex, if you please. Site the usage, please. I can't defend something I don't see. This is complete gibberish that shows he doesn't understand even the basics. Modulus of rupture is a measure of a material's strength in bending. Close. That is when it FAILS. Bending loads on a piece of wood (or other material) typically produce stress in both compression and tension at the same time. Oh really? Why that's all new news to this clown. Wow, thanks. Take a wood yardstick and hold it by the ends; now try to bend it into a U shape. The wood fibers on the inside of the curve will be in compression, while those on the outside will be in tension, simultaneously. If you apply enough bending moment you can break the stick. But what if you bend it as far as you can without breaking it and then let it go? Have you done any damage? Depends. Please tell us how you can tell. Give us all a REAL example. Use something more than modulus of rupture, or buy a vowel. It's quite possible tthat you have damaged the wood fibers that were in compression (the top of the stick). Almost certainly you will not have damaged the bottom of the stick, which was under tension. Really? How do you know? There are ways to know, or don't you know how to figure that part? So while you didn't break the stick, you might have caused compression failure on the side of the stick that was on the inside of the curve. This damage would be most acute on the top surface of the stick and would be progressivly less until the neutral axis (middle) of the stick. If you made a saw cut right across the point of bending, you would probably see -- under a magnifying glass -- wood fibers that have failed in compression. Don't need a magnifying glass, if you know what to look for. Idiot's comments about needing 10,000 pounds on top of the wood simply illustrate to everyone what a loudmouth know-nothing he is. I was talking about a bending force, or can't you read? All it takes is enough force to bend the plank more than you would normally do. Oh, please tell. How about that. How about a number a bit more specific than "more than you would normally do." How much is normal? Those numbers are in there. This does not have to be a lot of force. Once again, something more specific, please, professor? No? Oh well. You obviously show a lot more book knowledge than real application. You had damn well better understand how all of the figures for each species apply to how the specific stick will be used. You know nothing that anyone here should use to build an airplane. You said something back there about modulus of rupture being the most important. Yes it is important, but far from _all_ that is important. How about modulus of elasticity? Some woods will not bend much, until they suddenly rupture. Might want to know that, right? Some woods are very poor in tension, and splinter at the drop of a hat. Might want to know about that, too. YOU CAN NOT PICK AND CHOOSE WHAT FIGURES YOU WANT TO LOOK AT. YOU MUST USE THEM ALL, AND UNDERSTAND HOW TO USE THEM ALL. To say otherwise is to create a death trap, and irresponsible to try to convince others, that you don't need to consider the loads that will be placed on each individual part. Most people do not have the skills and understanding to consider all of the factors involved. It is VERY clear, at least you do not. YOU are one more fine example of newsgroups "gods" spouting off, and giving misinformation that could be deadly. Ever read the government's forrest products book? It's old, but still the best of its type. Try it. That is only a start. By the way, so everyone out there in newsgroup land can best judge how you are qualified to pass on all of your useful information, how about posting all of your qualifications? Education, degrees, how many wood airframes you have analyzed, how many you have built and flown? Any or all of those things. Please. Please. Use the Doctor's motto. First do no harm. You have some un-doing to do. Don't bother responding to me. You are off my radar; my blood pressure can't stand it. Please, group. Learn more from someone who knows more than him (or me) before taking this one's advise. Jerk. I hate being like this. -- Jim in NC |
How long have you two been married?
Don't DO that at this hour of the morning. I HATE iced tea coming out my
nose. {;-) Jim "Lou" wrote in message oups.com... How long have you two been married? |
![]() "Lou" wrote How long have you two been married? Ouch! g -- Jim in NC |
Sensenich Wood Prop Question | [email protected] | Owning | 3 | April 4th 05 02:32 PM |
wood grain question. | Fred the Red Shirt | Home Built | 1 | December 6th 04 02:13 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
Wood questions - Public Lumber Company, determining species at the lumberyard | Corrie | Home Built | 17 | September 17th 03 06:51 PM |
