Transponder
Old October 18th 05, 10:48 PM
John R. Copeland
Default Transponder
"Peter Clark" wrote in message ...
Doesn't removing the transponder from the tray disconnect it from the
static system and thus require a re certification under 91.411(2)
before it can be used IFR in controlled airspace?
No.
  #33
Old October 19th 05, 12:35 AM
kgruber
Default Transponder
YES
"John R. Copeland" wrote in message
news "Peter Clark" wrote in message
No.
  #34
Old October 19th 05, 01:02 AM
John R. Copeland
Default Transponder
"kgruber" wrote in message ...
YES
Your transponder has a barometric encoder *inside* it?
I've never had one like that.
  #36
Old October 19th 05, 08:02 AM
Dale Scroggins
Default Transponder
YES
Ackshully, it's 91.413(b). Removal from the panel (and reinstallation)
can introduce data correspondence error between the encoder and the
transponder. So it must be checked. A log entry referencing
transponder work should contain or be followed immediately by an entry
referencing 91.413.
  #37
Old October 19th 05, 08:30 AM
Dale Scroggins
Default Transponder
Jose wrote:
As to a transponder, and its vitial importance to the system (and to my
TCAS when sharing the airspace with VFR aircraft) a transponder's proper
functioning has importance to everyone using the system. Your proper
tire inflation does not.
Improper tire inflation can have a significant adverse impact on the
system and on safey, especially at busy airports such as those in class
B. Improper fueling can too, but I do fuel my own aircraft on occasion
rather than pay a professional.
The issue isn't whether the item in question is of "vital importance"
but whether it is simple or tricky to fix, which relates to the
likelyhood of a non-pro causing problems. It is not unreasonable to
expect that a stuck ident button is simple to fix. It is also not
unreasonable to expect that it could be tricky to fix. Therefore the
question is perfectly reasonable, and replies should be helpful rather
than insulting.
Jose
The issue isn't whether and item is of "vital importance", or whether it
is simple to fix. The issue is whether an owner/operator holds the
privilege to perform a task. The FARs allow an owner/pilot to air up
his tires, service struts, do a little brake work, touch up paint, fix
interior items, etc. The FARs allow the owner/pilot to remove and
install a panel-mounted radio. They prohibit him from repairing it
(other than tightening a knob or touching up paint). If he makes a
repair and notes it in the aircraft records, the FAA has three years to
catch him. If he makes a repair and makes no entry, he commits fraud,
and the FAA can prosecute at any later date. Parts 1, 43, and 91, as
related to preventive maintenance, maintenance, repair, and entries;
part 13 as to violations.
  #38
Old October 19th 05, 08:41 AM
Dale Scroggins
Default Transponder
class B. Improper fueling can too, but I do fuel my own aircraft on
occasion rather than pay a professional.
than insulting.
Jose
Should have checked Part 43, App. A before I replied. Section 31 says
he can remove panel-mounted radios EXCEPT transponders and DMEs. I'm
not sure now he can even tighten knobs or touch up paint.
  #39
Old October 19th 05, 02:16 PM
Jose
Default Transponder
The issue isn't whether and item is of "vital importance", or whether it is simple to fix. The issue is whether an owner/operator holds the privilege to perform a task.
True, and driving that issue is what I said above. The OP was merely
asking a question which should not bring the wrath of usenet upon him
(lotsaluck!) nor does it indicate any kind of disregard for the FARs.
Jose
Money: what you need when you run out of brains.
  #40
Old October 19th 05, 02:48 PM
Default Transponder
My my perch it indicated either an igorance or predisposition to disregard the FARs. You are very kind to conclude that it simply did not indicate any kind of disregard for
the FARs.
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Transponder petition Ian Cant Soaring 11 February 28th 04 06:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 06:37 PM
