DavidM wrote:
Has anyone reading this group had to degauss a firewall? My Warrior took a lightning strike last July while parked, melting a bit of the propeller tip and magnetizing much of the plane forward of the firewall (so that the compass always points towards the propeller). The engine has now been overhauled, and all engine parts and the mount degaussed, but after trying several compasses, we cannot get any to indicate properly -- something is still strongly magnetized. Tomorrow my AME (IA/A&P) will bring in a specialized meter and degaussing device to start trying to hunt down the problem, but I'm quite discouraged being grounded for this long. Thanks in advance for any help, David This is probably stating the obvious, but only the iron/steel stuff can be magnetized. A dime store (do those exist anymore?) compass should point to the magnetized part as you walk around the nose. Held too closely it will point to any iron/steel part magnetized or not, so start out at a distance where you start seeing a "disturbance in the force". -- Jim Pennino Remove .spam.sux to reply. |
![]() DavidM wrote: We've done the compass walkaround in great detail, and as best we can tell, the remaining problem is close to the firewall (the engine mount was already degaussed in Halifax while the engine was being How about the rudder pedal/bar assemblies? Also the control yoke shafts and central control column/T-bar/chain drive assembly? Aren't those all also made of steel in a PA28? |
A proper airplane degausser and flux meter (??) arrived at the shop
from Halifax, and my AME (= IA/A&P) spent the day carefully degaussing my plane. Everything that could be easily removed, like the steering rods, was degaussed externally (the mount and main engine had already been degaussed during overhaul). The main magnetism was on the left side of the firewall, particularly where there's a steel band for bolts to attach. Working very carefully (to avoid introducing any new, opposite magnetism) he worked over it bit by bit, and believes he's got it all -- at least, a handheld compass in the plane now indicates close to the correct direction, rather than always north or north-northwest. Every ferrous part in the plane showed a bit deflection on the meter before degaussing. All the best, David |
On 4 Nov 2005 04:48:20 -0800, "DavidM"
wrote: A proper airplane degausser and flux meter (??) arrived at the shop from Halifax, and my AME (= IA/A&P) spent the day carefully degaussing my plane. Everything that could be easily removed, like the steering rods, was degaussed externally (the mount and main engine had already been degaussed during overhaul). The main magnetism was on the left side of the firewall, particularly where there's a steel band for bolts to attach. Working very carefully (to avoid introducing any new, opposite magnetism) he worked over it bit by bit, and believes he's got it all -- at least, a handheld compass in the plane now indicates close to the correct direction, rather than always north or north-northwest. Every ferrous part in the plane showed a bit deflection on the meter before degaussing. All the best, David I wish you well, and hope you got it all. Thanks for sharing your tribulations with this ordeal. z |
Where do you live Dave?
We fly a Warrior (151) out of Fredericton, - was in HFX last weekend.. Dave On 4 Nov 2005 04:48:20 -0800, "DavidM" wrote: A proper airplane degausser and flux meter (??) arrived at the shop from Halifax, and my AME (= IA/A&P) spent the day carefully degaussing my plane. Everything that could be easily removed, like the steering rods, was degaussed externally (the mount and main engine had already been degaussed during overhaul). The main magnetism was on the left side of the firewall, particularly where there's a steel band for bolts to attach. Working very carefully (to avoid introducing any new, opposite magnetism) he worked over it bit by bit, and believes he's got it all -- at least, a handheld compass in the plane now indicates close to the correct direction, rather than always north or north-northwest. Every ferrous part in the plane showed a bit deflection on the meter before degaussing. All the best, David |
Dave wrote:
We fly a Warrior (151) out of Fredericton, - was in HFX last weekend.. I'm based at Ottawa (CYOW), but stopped at Moncton, Port Hawkesbury, Halifax, and Fredericton as part of a family trip to Cape Breton in summer 2004 -- it's a beautiful area for flying, especially around the Bay of Fundy and along the Northumberland Strait. I'd strongly recommend that any U.S. pilots in New England reading this make the short flight up there. This summer, because of the lightning strike, we ended up cancelling our trip to the Gaspe, along with a few other planned trips. You guys must have had quite a time early in the summer with all the problems at Halifax airport. Did you see a lot of diversions into Fredericton? All the best, David |
Hi Dave!
Your assessment is correct... It was very busy here at YFC, many diversions to Fredericton and Moncton. Moncton actually tried to capitalize on it, but the people here at YFC just tried to help out... We get a lot of diversions here from HFX and Moncton anyway, and from Saint John. Of all these airports, YFC is the only "inland" one...so this situation is normal, the weather here in Fredericton is usually just better.. Sorry your trip was cut short...bummer! I have following your thread with "Warrior" interest. Ours is a '77 151.. new to us in Aug. Just "learning" our "new" plane! Discovered a phone plug in the map pocket 2 weeks ago, with wire attached! Previous owner(s) never mentioned it, no documentation. Asked them..."Thats your audio input to the intercom" ALRRIGGGHT! Fired up a $49 mp3 player, plugged in the wire and volia! last weekend to HFX, 6500 ft over the Bay of fundy, smooooth air, sun is shining, the Lyc is purring,crew & pax tuning everything from Meatloaf to Enya..... Hard to get it any better than that! ![]() (Hope Jay reads this! ) hehe... Hope you Warrior gets better soon! Dave On 6 Nov 2005 05:20:00 -0800, "DavidM" wrote: Dave wrote: We fly a Warrior (151) out of Fredericton, - was in HFX last weekend.. I'm based at Ottawa (CYOW), but stopped at Moncton, Port Hawkesbury, Halifax, and Fredericton as part of a family trip to Cape Breton in summer 2004 -- it's a beautiful area for flying, especially around the Bay of Fundy and along the Northumberland Strait. I'd strongly recommend that any U.S. pilots in New England reading this make the short flight up there. This summer, because of the lightning strike, we ended up cancelling our trip to the Gaspe, along with a few other planned trips. You guys must have had quite a time early in the summer with all the problems at Halifax airport. Did you see a lot of diversions into Fredericton? All the best, David |
Warrior cruise RPM settings | lardsoup | Piloting | 35 | October 9th 05 11:59 PM |
Fuel dip tube for Piper Warrior? | TTA Cherokee Driver | Owning | 16 | May 3rd 04 05:42 PM |
Warrior POH | Michael Egan | Owning | 2 | February 4th 04 05:41 PM |
Warrior POH | Michael Egan | Piloting | 2 | February 4th 04 05:41 PM |
Warrior Strobe Tube Replacement | Jerry Malin | Owning | 3 | September 29th 03 04:02 AM |
