Denny wrote:
WIth the flux meter and a Color TV degausser coil, you should be able to cure it... Even a compass will help you pick out the magnetized areas in the engine compartment for giving the buzz treatment... The key to using the degausser is to buzz the part and keep the power on while you withdraw the coil, not put the coil against it and just turn the power on and off... How about a tape eraser? Would be easier to get into tight places... |
Yes, a bulk tape eraser will work.
"Darrel Toepfer" wrote in message .. . Denny wrote: How about a tape eraser? Would be easier to get into tight places... |
![]() I strongly doubt a tape degausser will do you much good. Likewise a color-TV coil. You need a lot of field strength to clean [really, re-randomize..] structual steel. You also need to be able to get that field where it's needed. Tapes and TV sets are orders of magnitude more subtle than the results of a strike. But feel free to try; just get the compasses well away before you start. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
It doesn't matter how intense the strike was. The metal can only hold a
certain magnetic flux. If you exceed the metals maximum flux then the degausser will work. The TV degausser was designed to degause iron and steel, and so it can exceed the maximum magnetic flux of steel. It should work fine. You can also use an AC motor as a degausser, and a small compass as a field detector. The Navy still has a number of degaussing stations in operation. If you can just convince them to let you park your plane on the deck... "David Lesher" wrote in message ... I strongly doubt a tape degausser will do you much good. Likewise a color-TV coil. You need a lot of field strength to clean [really, re-randomize..] structual steel. You also need to be able to get that field where it's needed. Tapes and TV sets are orders of magnitude more subtle than the results of a strike. But feel free to try; just get the compasses well away before you start. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
"soxinbox" wrote in message
.. . It doesn't matter how intense the strike was. The metal can only hold a certain magnetic flux. If you exceed the metals maximum flux then the degausser will work. The TV degausser was designed to degause iron and steel, and so it can exceed the maximum magnetic flux of steel. It should work fine. You can also use an AC motor as a degausser, and a small compass as a field detector. - snip - I'm really curious. How does one go about using "an AC motor as a degausser"? Not doubting - would like to know something about the technique for doing that. DL |
An AC motor works by rotating an AC magnetic field around a rotor, thus any
AC motor is generating an AC magnetic field. You can use it to degauss something by placing the energized motor close to the object and slowly pulling the motor away. Basically this is how all degaussing equipment works, only some equipment decreases the field electronically, and some decreases the field by increasing the distance from the object. "DL" wrote in message k.net... "soxinbox" wrote in message .. . It doesn't matter how intense the strike was. The metal can only hold a certain magnetic flux. If you exceed the metals maximum flux then the degausser will work. The TV degausser was designed to degause iron and steel, and so it can exceed the maximum magnetic flux of steel. It should work fine. You can also use an AC motor as a degausser, and a small compass as a field detector. - snip - I'm really curious. How does one go about using "an AC motor as a degausser"? Not doubting - would like to know something about the technique for doing that. DL |
Warrior cruise RPM settings | lardsoup | Piloting | 35 | October 9th 05 11:59 PM |
Fuel dip tube for Piper Warrior? | TTA Cherokee Driver | Owning | 16 | May 3rd 04 05:42 PM |
Warrior POH | Michael Egan | Owning | 2 | February 4th 04 05:41 PM |
Warrior POH | Michael Egan | Piloting | 2 | February 4th 04 05:41 PM |
Warrior Strobe Tube Replacement | Jerry Malin | Owning | 3 | September 29th 03 04:02 AM |
