Hobbs Switch
Old November 10th 06, 09:27 PM posted to rec.aviation.homebuilt
ccwillwerth
Default Hobbs Switch
Hi, I would like to wire my hobbs so that it only runs when the engine is
running. Is there an oil pressure switch or something that could be used?
Charlie
Old November 10th 06, 09:29 PM posted to rec.aviation.homebuilt
RST Engineering
Hobbs switches are a division of Stewart-Warner. Stewart-Warner parts are
available at your local NAPA Aviation Parts Store.
"ccwillwerth" wrote in message
Charlie
Old November 10th 06, 09:36 PM posted to rec.aviation.homebuilt
Drew Dalgleish
I used an oil pressure switch teed into the line to the oil pressure
gauge. When you turn on the master it puts power to one side of the
switch and once there's pressure it closes the switch and sends power
to the hourmeter.
Ok!!! it's really a DATCON #102033. The meter records time. It runs from
battery power. I would like to wire it in some way so that it only operates
when the engine is running. As it is now, the only thing I can figure to do
is wire it to the master so that when it is on, the meter runs. This will
not provide an accurate engine or airframe time, therefore, I would like to
have it only run when the engine is running. Does anyone have any ideas?
Charlie
Charlie
Old November 10th 06, 10:21 PM posted to rec.aviation.homebuilt
ccwillwerth
Charlie
Charlie
Old November 10th 06, 11:05 PM posted to rec.aviation.homebuilt
Steve A
buy this oil pressure switch:
http://www.aircraftspruce.com/catalo...obbsswitch.php
wire it to the Datcon and engine this way:
http://www.aeroelectric.com/PPS/Engi...Oil_P_Warn.pdf
The low oil pressure warning buzzer and light shown on the schematic are
optional. They are not required for the Datcon hour meter function.
Old November 16th 06, 04:26 PM posted to rec.aviation.homebuilt
Peter Dohm
Nicely stated, and saved. :-)
Peter
Cessna PTT switch normal? Mark Hansen Owning 9 September 23rd 06 05:12 AM
74 Archer ignition switch question Mike Noel Owning 9 September 10th 06 10:46 PM
Cessna landing light switch; solved! jim Owning 1 January 15th 06 10:33 PM
What does REC mean on the switch? Jose Piloting 10 June 15th 05 05:55 AM
C-172 landing light switch JFLEISC Owning 10 May 5th 04 11:05 PM
