Nyal,
I love a challenge(g). However, including a sweep screen with photo-optical sensor to provide data to a remote digital angle-of-slip indicator, would cause a bodacious increase in the $9 selling price. We could go low tech though. Since the MKII yaw string already comes with transparent turbulator base and a single light colored alignment dot*, it wouldn't be that much trouble to include two additional alignment dots and a template to install them at say, 10 degrees each side of center. *The center alignment dot, affixed to the inside of the canopy surface, is light colored so it doesn't tend to attract the eye, tricking it into thinking it's outside traffic, as would a dark colored dot. As an aside, I've seen several MKII yaw string installations where the pilot chose not to install the included alignment dot as all. So clearly all this is a matter of preference . . . as is the decision to continue using that ugly old tape and yarn!!. -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." "Nyal Williams" wrote in message ... Some of us are waiting with abated breath (nothing fishy here) for the Mark III calibrated model. It is reported to have a transparent sweep screen underneath it so as to measure the precise angle of slip and aid in selecting the amount of rudder input required. At 17:06 29 January 2007, Bumper wrote: Nor did they mention the vastly improved yaw string, the MKII 'high tech' yaw string! The MKII is reputed, by generally refutable and unreliable sources, to increase L/D by at least 2 points - - but who's counting. This from the inventor of the 'QV quiet vent kit' (which really does decrease noise from the Mecaplex flip-out window vent by a full 10 db as measured in an ASH26E at 60 knots). Contact me directly for more info. I'll have a supply of both with me at the SSA convention. bumper ZZ 'Dare to be different . . . circle in sink.' 'Ralph Jones' wrote in message . .. On 29 Jan 2007 03:08:22 -0800, 'Doug Haluza' wrote: The Wikipedia article on the yaw string is featured on the main page today in the 'Did you know....' section as follows: 'Did you know...' ...that the yaw string, a simple tuft of yarn used as a flight instrument by the Wright brothers, is still in use today?' http://en.wikipedia.org/wiki/Yaw_string Hm...didn't point out the importance of using a metric yaw string on German sailplanes...;-) rj |
Darn things work even better when you tape both ends down. Just have
to make sure it's on straight first... And they last longer on the inside of the canopy, anyway. 66 |
Shut up!!
How am I gonna get rich selling these things if you post accurate info like that? bumper "kirk.stant" wrote in message oups.com... Darn things work even better when you tape both ends down. Just have to make sure it's on straight first... And they last longer on the inside of the canopy, anyway. 66 |
On Jan 29, 4:22 pm, "bumper" wrote:
Shut up!! How am I gonna get rich selling these things if you post accurate info like that? Same way everybody makes a small fortune in aviation - start with a big one! Actually, you should consider using the blank surface of the yawstring for advertising - how about string cheese? Or baling wire? 66 |
light twins? | Bellsouth News Server | Home Built | 83 | August 12th 05 02:56 AM |
Yaw String in a Spin | John Galloway | Soaring | 52 | January 21st 05 10:14 PM |
Yaw String refference - Spinning | Vassilios Mazis | Soaring | 1 | January 18th 05 07:30 AM |
Long Island Crash - Kite String? | Neb Okla | Rotorcraft | 5 | September 3rd 04 05:43 PM |
String in the middle does not protect you from a spin | Jim | Soaring | 10 | January 30th 04 02:57 PM |
