Wood Prop Question
Old April 5th 07, 05:19 PM posted to rec.aviation.homebuilt
cavelamb himself
Default Wood Prop Question
Kyle Boatright wrote:
Those of us who fly behind (or in front of) wooden props usually reduce RPM
significantly when entering rain. I reduce RPM to 1900 in rain, or I see
minor damage, despite the urethane leading edges. For me, 1900 rpm results
in a rotational tip speed of about 400 mph. This doesn't consider the
forward motion of the aircraft.
In WWII, more than a few combat aircraft used wooden propellers - Spitfires,
Hurricanes, and Me-109's being high profile examples. However, I have never
heard of any rain/prop issues with those aircraft. And I'm sure there were
plenty of occasions where those aircraft were flown full-out in rain. FYI,
with the Spit/merlin combination, the prop is geared to roughly half the
engine speed of 3,000 RPM. At 1500 prop rpm, a 10.75' diameter prop has a
tip speed of roughly 575 mph.
That's the kind of tip speed that will supposedly wreck a wooden prop in the
rain. So, what was different about those props? Were the blades
essentially disposable and nobody gave a second thought to trashing a set?
Did the blades incorporate some sort of technology that I've missed? (Brass
leading edges don't count - to the best of my knowledge, Spits didn't have
'em.)
Thoughts?
KB
I believe most of those old wood props had a brass leading edge cover.
That ought to protect the wood from rain erosion.
OTOH, the (metal) tail rotor on the Hughes OH6A woudld last about 5
minutes in rain.
Richard
Old April 6th 07, 02:01 AM posted to rec.aviation.homebuilt
Kyle Boatright
"cavelamb himself" wrote in message
link.net...
RPM significantly when entering rain. I reduce RPM to 1900 in rain, or
I see minor damage, despite the urethane leading edges. For me, 1900 rpm
results in a rotational tip speed of about 400 mph. This doesn't consider
the forward motion of the aircraft.
Spitfires, Hurricanes, and Me-109's being high profile examples.
However, I have never heard of any rain/prop issues with those aircraft.
And I'm sure there were plenty of occasions where those aircraft were
flown full-out in rain. FYI, with the Spit/merlin combination, the prop
is geared to roughly half the engine speed of 3,000 RPM. At 1500 prop
rpm, a 10.75' diameter prop has a tip speed of roughly 575 mph.
the rain. So, what was different about those props? Were the blades
set? Did the blades incorporate some sort of technology that I've missed?
(Brass leading edges don't count - to the best of my knowledge, Spits
didn't have 'em.)
Thoughts?
KB
I'm 99% sure that the props I'm talking about didn't have brass leading
edges. The next time you're at an airshow where a Spitfire is on display,
take a close look at the prop. On many (most?, all?) the prop is wood, and
you can't see a transition between a brass leading edge and the wood blade.
I've done this inspection several times at Osh and SnF...
KB
minutes in rain.
Richard
Old April 6th 07, 03:41 AM posted to rec.aviation.homebuilt
cavelamb himself
link.net...
didn't have 'em.)
Thoughts?
KB
KB
Sorry 'bout that, Kyle.
I was thinking Spads and Sopwiths...
Richard
Old April 10th 07, 08:25 PM posted to rec.aviation.homebuilt
SkyDaddy
link.net...
didn't have 'em.)
Thoughts?
KB
KB
minutes in rain.
Richard- Hide quoted text -
- Show quoted text -- Hide quoted text -
The MK XIV Spit had a five-bladed wooden prop. Ironically, the
manufacturer is now owned by a German conglomerate.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
FS: Wood prop for experimental aircraft Glasair Aviation Marketplace 0 September 29th 05 06:06 PM
Installing a wood prop... SteveR Home Built 19 July 24th 05 06:42 AM
Sensenich Wood Prop Question [email protected] Owning 3 April 4th 05 02:32 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
