Need pinout for Terra A3000 blind encoder
Old November 18th 07, 01:03 AM posted to rec.aviation.owning
dave
Default Need pinout for Terra A3000 blind encoder
I need the pinout for the Terra A3000 encoder
Thanks
Dave
Old November 18th 07, 01:27 PM posted to rec.aviation.owning
Mike Spera
Are you trying to install it of fix it?
Mike
Thanks
Dave
Old November 18th 07, 03:14 PM posted to rec.aviation.owning
dave
Mike
Thanks
Dave
Mike,
A little bit of both.
I do transponder/altimeter certifications and have an encoder test box
I'm designing up and want to know if it will be compatible with the
Terra. If not I will need to make an adapter to go between the two.
This will help me adjust them when not connected to the transponder.
Thanks
Dave
Old November 22nd 07, 04:19 PM posted to rec.aviation.owning
mikem
It is the same as an AmeriKing AK-350 and Narco AR850
Transponder for sale Terra TRT 250D/AK-35 encoder Bill Dodson Soaring 0 March 29th 07 07:27 AM
Pinout for TERRA TRT-250 transponder Turaga Home Built 10 November 9th 06 12:38 AM
FS: Blind Altitude Encoder nobody Aviation Marketplace 0 August 6th 05 06:58 PM
KNS-80/KNI-520 encoder bad? [email protected] Owning 4 September 7th 04 06:27 PM
Altitude encoder Chad Lemmen Owning 9 August 23rd 03 01:13 AM
