In that case I doubt I'd bitch about the $80 cost for 4 bolts.
Stuart & Kathryn Fields wrote: Well, I use 4 of these bolts in the "Jesus" bolt position whose job is to keep my my entire rotor blade system from departing like a kids toy. Yes, I want to be 500' in the air not even wondering if I got the bolts that I thought I did. Stu "Maxwell" wrote in message ... "cavelamb himself" wrote in message ... wrote: On Jan 3, 2:45 pm, "Stuart & Kathryn Fields" wrote: Recent quote for 16 of these bolts was about $20.00 each!! Anyone out there with a less expensive source? Since I presume you're dealing with an experimental aircraft, and a MS20074 bolt is a coarse thread (the only coarse thread aircraft structural bolt I know of), 125 ksi, drilled head hex bolt, why not just use a grade 5 or grade 8 auto bolt? They are quite good quality if you buy from the right source. Try some of the race car suppliers maybe. Regards, Bud It might be quite good quality - or it might be junk. How are you going to know??? If you go with a quailty manufacturer that will certify the grade, specify rolled threads, and have them individually magnafluxed, you should be good to go. |
Well there is a little more to it. I'm assisting other builders and the
bolt count goes up @ 4/ ship and it adds up quickly. I'm sure that there is a source somewhere at more like $10/bolt I bought "Supertanium" bolts for less than $20 each and these are a high strength Titatanium alloy in the 200ksi region. The MS are of the grade 5 variety, coarse thread and the only thing special is the drilled head. $20 each is excessive. Stu "Gig601XLBuilder" wrote in message ... In that case I doubt I'd bitch about the $80 cost for 4 bolts. Stuart & Kathryn Fields wrote: Well, I use 4 of these bolts in the "Jesus" bolt position whose job is to keep my my entire rotor blade system from departing like a kids toy. Yes, I want to be 500' in the air not even wondering if I got the bolts that I thought I did. Stu "Maxwell" wrote in message ... "cavelamb himself" wrote in message ... wrote: On Jan 3, 2:45 pm, "Stuart & Kathryn Fields" wrote: Recent quote for 16 of these bolts was about $20.00 each!! Anyone out there with a less expensive source? Since I presume you're dealing with an experimental aircraft, and a MS20074 bolt is a coarse thread (the only coarse thread aircraft structural bolt I know of), 125 ksi, drilled head hex bolt, why not just use a grade 5 or grade 8 auto bolt? They are quite good quality if you buy from the right source. Try some of the race car suppliers maybe. Regards, Bud It might be quite good quality - or it might be junk. How are you going to know??? If you go with a quailty manufacturer that will certify the grade, specify rolled threads, and have them individually magnafluxed, you should be good to go. |
On Jan 4, 10:05*am, "Stuart & Kathryn Fields" wrote:
The MS are of the grade 5 variety, coarse thread and the only thing special is the drilled head. *$20 each is excessive. How about you buy a full box of Grade 8 bolts, test half or quarter of them to destruction in shear and tension, and then reject the box if any fail below expected values. If they pass, test the rest to the implementation design limits and then drill the heads on your drill press using a carbide bit. That might work. Bob K. |
"Bob Kuykendall" wrote in message
... How about you buy a full box of Grade 8 bolts, test half or quarter of them to destruction in shear and tension, and then reject the box if any fail below expected values. If they pass, test the rest to the implementation design limits and then drill the heads on your drill press using a carbide bit. That might work. +++++++++++++++++++++++++++++++++++ I did that with my prop bolts. Better buy twice as many plus a dozen extra carbide bits. Anybody wanna buy about six grade 8 prop bolts with busted carbide bits imbedded in the hex heads? ![]() Rich S. |
Rich S. wrote:
"Bob Kuykendall" wrote in message ... How about you buy a full box of Grade 8 bolts, test half or quarter of them to destruction in shear and tension, and then reject the box if any fail below expected values. If they pass, test the rest to the implementation design limits and then drill the heads on your drill press using a carbide bit. That might work. +++++++++++++++++++++++++++++++++++ I did that with my prop bolts. Better buy twice as many plus a dozen extra carbide bits. Anybody wanna buy about six grade 8 prop bolts with busted carbide bits imbedded in the hex heads? ![]() Rich S. I have to report the same levels of sucess! Those tiny little bits break when they start to come out the bottom side. BTW, Why Grade 8? Seems like those might be a but - brittle? Richard |
cavelamb himself wrote:
I have to report the same levels of sucess! Those tiny little bits break when they start to come out the bottom side. BTW, Why Grade 8? Seems like those might be a but - brittle? Richard Because a grade 8 bolt on a bad day still beats a grade 5 for strength on its best day. Someone showed the numbers on that issue either here or one of the list-servers I subscribe to. Dave |
![]() "Stuart & Kathryn Fields" wrote in message ... Well, I use 4 of these bolts in the "Jesus" bolt position whose job is to keep my my entire rotor blade system from departing like a kids toy. Yes, I want to be 500' in the air not even wondering if I got the bolts that I thought I did. Stu "Maxwell" wrote in message ... "cavelamb himself" wrote in message ... wrote: On Jan 3, 2:45 pm, "Stuart & Kathryn Fields" wrote: Recent quote for 16 of these bolts was about $20.00 each!! Anyone out there with a less expensive source? Since I presume you're dealing with an experimental aircraft, and a MS20074 bolt is a coarse thread (the only coarse thread aircraft structural bolt I know of), 125 ksi, drilled head hex bolt, why not just use a grade 5 or grade 8 auto bolt? They are quite good quality if you buy from the right source. Try some of the race car suppliers maybe. Regards, Bud It might be quite good quality - or it might be junk. How are you going to know??? If you go with a quailty manufacturer that will certify the grade, specify rolled threads, and have them individually magnafluxed, you should be good to go. Well in that case I think I would consider having them independently inspected even if I purchased AN certified hardware. I don't think it is horribly expensive. |
On Jan 4, 10:12*am, "Stuart & Kathryn Fields" wrote:
Well, *I use 4 of these bolts in the "Jesus" bolt position whose job is to keep my my entire rotor blade system from departing like a kids toy. *Yes, I want *to be 500' in the air not even wondering if I got the bolts that I thought I did. Stu"Maxwell" wrote in message ... "cavelamb himself" wrote in message ... wrote: On Jan 3, 2:45 pm, "Stuart & Kathryn Fields" wrote: Recent quote for 16 of these bolts was about $20.00 each!! *Anyone out there with a less expensive source? Since I presume you're dealing with an experimental aircraft, and a MS20074 bolt is a coarse thread (the only coarse thread aircraft structural bolt I know of), 125 ksi, drilled head hex bolt, why not just use a grade 5 or grade 8 auto bolt? They are quite good quality if you buy from the right source. Try some of the race car suppliers maybe. Regards, Bud It might be quite good quality - or it might be junk. How are you going to know??? If you go with a quailty manufacturer that will certify the grade, specify rolled threads, and have them individually magnafluxed, you should be good to go.- Hide quoted text - - Show quoted text - I agree that I would want top quality for the "Jesus" nut as we used to call them. I also agree with the others that I wouldn't complain about $80 for them. Not the place to try and save money in my opinion. As for not knowing what you have, ARP makes bolts for racing cars that are made to the same AMS (aerospace metallurgical standard) specs as aircraft. I doubt that they will be any cheaper however. They make big end rod bolts to 300 ksi using Aermet 100, the strongest structural metal available. They probably cost as much or more as any MS bolt. As I said, MS20074 bolts are only 125,000 psi strength bolts, and since they are coarse thread, are not as strong as an AN bolt in tension. http://www.arp-bolts.com/ Regards, Bud |
Needed 4 socket cap bolts | Udo | Soaring | 2 | November 29th 07 02:21 PM |
Torque for prop bolts | Scott | Home Built | 15 | August 29th 06 02:58 PM |
Metric Aircraft Nuts and Bolts | John Scott | Soaring | 6 | December 14th 05 08:54 PM |
Oversized bolts | Kjell Sivertsen | Owning | 7 | April 14th 05 05:02 AM |
Source for Bolts | Dave | Home Built | 2 | May 20th 04 08:09 PM |
