On Apr 16, 8:46 am, Greg Arnold wrote:
Why does Tost change the parts to use DOT fluid? Which glider manufactures use brakes that take the red stuff, and which use DOT fluid? bumper wrote: Paul, As Gary Evans mentioned, there are basically two brake fluids used in gliders. The "red stuff" Mil Spec 5606 oil (which most GA aircraft use) and DOT # automotive type fluid. 5605 wants to have Buna-N seals and O-rings while the DOT fluid uses EPDM rubber. You mentioned corrosion and this raises some flags. Cleveland parts, that Tost uses - changing the rubber parts to EPDM, were never really intended for use with DOT fluid. The problem is that DOT fluid is hygroscopic and whatever moisture gets into the fluid can corrode the bare aluminum surfaces of the caliper and piston (later pistons were anodized and this helps some). To find out if the piston is anodized, see if it conducts when touched with the leads of an ohm meter as the anodize surface is an insulator. If you have corrosion in the caliper bore or in the O-ring groove of the piston, you will likely have leakage again, probably sooner than later. One fix is to have the caliper bore machined and brass sleeved along with anodizing the piston. If anyone needs a free EPDM O-ring (for DOT fluid) for the Cleveland 300 series caliper, contact me via email (bumperm at att dot fish net) - remove the scaley thing) to get the address to send a self-addressed stamped envelope. bumper Quiet Vent - reduces vent noise by 10 dba "Paul Cordell" wrote in message ... It's Done! Thanks Dave Nadler and Uncle Hank for the off-line notes. This Soaring community is always surprising. I talked to Monty@ M & H Soaring this morning about the spec's for the Pads and O-ring. Then went over to Aircraft Spruce to get the parts. After I looked at their web site, I still had some questions about the rivets. I called a buddy that is an ex '20 owner and RV-7 builder to ask about the rivets. He lives about 100 miles away. As we talked, he walked out to his Hanger and went thru some stuff on his work bench. He had exactly the parts I needed. When would you like to do this he asked?? I told him that if he wanted to "help", it would be on his schedule........He responded, I'll be there in an Hour. He was and did the whole job as I "supervised". Cleaned and polished, pads and ring with a full bleed and new fluid. The system in general was in good shape. Just slight corrosion and some gunk. I supplied him with 1 soda for all the trouble. He'll be back next weekend for a test flight. Paul I've wondered myself - Possibly for compatibility with the master cylinder components scavenged from motorcycles ? Beringer systems use DOT fluid (and work extremely well, and are light). I had an HP that used the red stuff. I don't know about other glider hydraulic brakes out there. The Cleveland adaptations are, um, a bit problematic... See ya, Dave |
Uses the red stuff (5606).......Schleicher, Genesis, others?
Uses the clear stuff (DOT 3)......Grob, Schempp-Hirth, DG Look at your master cylinder, if its got red stuff in it............use the red stuff, if its got clear stuff............ BTW, you can replace a chewed up disk & pads for just over $100 bucks, see Aircraft Spruce & Specialty p/n 164-01700. Faster than trying to get Midas to turn your scored disk, it bolts on using the 3 hub bolts. JJ wrote: On Apr 16, 8:46 am, Greg Arnold wrote: Why does Tost change the parts to use DOT fluid? Which glider manufactures use brakes that take the red stuff, and which use DOT fluid? bumper wrote: Paul, As Gary Evans mentioned, there are basically two brake fluids used in gliders. The "red stuff" Mil Spec 5606 oil (which most GA aircraft use) and DOT # automotive type fluid. 5605 wants to have Buna-N seals and O-rings while the DOT fluid uses EPDM rubber. You mentioned corrosion and this raises some flags. Cleveland parts, that Tost uses - changing the rubber parts to EPDM, were never really intended for use with DOT fluid. The problem is that DOT fluid is hygroscopic and whatever moisture gets into the fluid can corrode the bare aluminum surfaces of the caliper and piston (later pistons were anodized and this helps some). To find out if the piston is anodized, see if it conducts when touched with the leads of an ohm meter as the anodize surface is an insulator. If you have corrosion in the caliper bore or in the O-ring groove of the piston, you will likely have leakage again, probably sooner than later. One fix is to have the caliper bore machined and brass sleeved along with anodizing the piston. If anyone needs a free EPDM O-ring (for DOT fluid) for the Cleveland 300 series caliper, contact me via email (bumperm at att dot fish net) - remove the scaley thing) to get the address to send a self-addressed stamped envelope. bumper Quiet Vent - reduces vent noise by 10 dba "Paul Cordell" wrote in message ... It's Done! Thanks Dave Nadler and Uncle Hank for the off-line notes. This Soaring community is always surprising. I talked to Monty@ M & H Soaring this morning about the spec's for the Pads and O-ring. Then went over to Aircraft Spruce to get the parts. After I looked at their web site, I still had some questions about the rivets. I called a buddy that is an ex '20 owner and RV-7 builder to ask about the rivets. He lives about 100 miles away. As we talked, he walked out to his Hanger and went thru some stuff on his work bench. He had exactly the parts I needed. When would you like to do this he asked?? I told him that if he wanted to "help", it would be on his schedule........He responded, I'll be there in an Hour. He was and did the whole job as I "supervised". Cleaned and polished, pads and ring with a full bleed and new fluid. The system in general was in good shape. Just slight corrosion and some gunk. I supplied him with 1 soda for all the trouble. He'll be back next weekend for a test flight. Paul I've wondered myself - Possibly for compatibility with the master cylinder components scavenged from motorcycles ? Beringer systems use DOT fluid (and work extremely well, and are light). I had an HP that used the red stuff. I don't know about other glider hydraulic brakes out there. The Cleveland adaptations are, um, a bit problematic... See ya, Dave |
On Apr 16, 6:11*am, JJ Sinclair wrote:
Uses the red stuff (5606).......Schleicher, Genesis, others? Uses the clear stuff (DOT 3)......Grob, Schempp-Hirth, DG Look at your master cylinder, if its got red stuff in it............use the red stuff, if its got clear stuff............ BTW, you can replace a chewed up disk & pads for just over $100 bucks, see Aircraft Spruce & Specialty p/n 164-01700. Faster than trying to get Midas to turn your scored disk, it bolts on using the 3 hub bolts. JJ wrote: On Apr 16, 8:46 am, Greg Arnold wrote: Why does Tost change the parts to use DOT fluid? Which glider manufactures use brakes that take the red stuff, and which use DOT fluid? bumper wrote: Paul, As Gary Evans mentioned, there are basically two brake fluids used in gliders. The "red stuff" Mil Spec 5606 oil (which most GA aircraft use) and DOT # automotive type fluid. 5605 wants to have Buna-N seals and O-rings while the DOT fluid uses EPDM rubber. You mentioned corrosion and this raises some flags. Cleveland parts, that Tost uses - changing the rubber parts to EPDM, were never really intended for use with DOT fluid. The problem is that DOT fluid is hygroscopic and whatever moisture gets into the fluid can corrode the bare aluminum surfaces of the caliper and piston (later pistons were anodized and this helps some). To find out if the piston is anodized, see if it conducts when touched with the leads of an ohm meter as the anodize surface is an insulator. If you have corrosion in the caliper bore or in the O-ring groove of the piston, you will likely have leakage again, probably sooner than later. One fix is to have the caliper bore machined and brass sleeved along with anodizing the piston. If anyone needs a free EPDM O-ring (for DOT fluid) for the Cleveland 300 series caliper, contact me via email (bumperm at att dot fish net) - remove the scaley thing) to get the address to send a self-addressed stamped envelope. bumper Quiet Vent - reduces vent noise by 10 dba "Paul Cordell" wrote in message ... It's Done! Thanks Dave Nadler and Uncle Hank for the off-line notes. This Soaring community is always surprising. * I talked to Monty@ M & H Soaring this morning about the spec's for the Pads and O-ring. Then went over to Aircraft Spruce to get the parts. * *After I looked at their web site, I still had some questions about the rivets. *I called a buddy that is an ex '20 owner and RV-7 builder to ask about the rivets. * He lives about 100 miles away. * * As we talked, he walked out to his Hanger and *went thru some stuff on his work bench. * He had exactly the parts I needed. * *When would you like to do this he asked?? * I told him that if he wanted to "help", it would be on his schedule........He responded, I'll be there in an Hour. * He was and did the whole job as I "supervised". * * Cleaned and polished, pads and ring with a full bleed and new fluid. * The system in general was in good shape. * *Just slight corrosion and some gunk. * *I supplied him with 1 soda for all the trouble. * *He'll be back next weekend for a test flight. Paul I've wondered myself - Possibly for compatibility with the master cylinder components scavenged from motorcycles ? Beringer systems use DOT fluid (and work extremely well, and are light). I had an HP that used the red stuff. I don't know about other glider hydraulic brakes out there. The Cleveland adaptations are, um, a bit problematic... See ya, Dave- Hide quoted text - - Show quoted text - Paul, Glad to hear your glider brake is back in service. As a general question to all those really knowledgeable folks out there, What are the advantages/disadvantages of 5606? One disadvantage I know of is that it really has strong smell that's hard to get out of stuff. Others? Dot 3 will rip the paint off nearly anything (I've used it to strip small painted parts), is hydroscopic - not a problem in the SW desert if you do a full bleed annually, and is available just about everywhere. Any reason NOT to convert? (Aside from the paint thing...) In my limited experience with glider brakes it appears that all the 'seals' used are off-the-shelf o-rings, as opposed to specially formed seals found in automotive and motorycle braking systems. This would seem to make conversion to DOT 3 a snap. Am I missing something here? TIA Jim |
Tost brake bolt shears off - the answer | Jack Glendening | Soaring | 1 | September 30th 07 01:16 PM |
Tost brake bolt shears off | Jack Glendening[_2_] | Soaring | 25 | September 10th 07 10:15 PM |
Glider Drum Brake Rebuild | [email protected] | Soaring | 4 | January 17th 06 09:39 PM |
disk loading | Roopah Vi Tam | Rotorcraft | 1 | September 9th 04 05:45 PM |
Eberle Surge Brake Rebuild | Jim Hendrix | Soaring | 0 | June 18th 04 08:28 PM |
