Altimeter Question
Old April 17th 08, 05:37 PM posted to rec.aviation.piloting,rec.aviation.student
Tauno Voipio
Default Altimeter Question
WingFlaps wrote:
On Apr 18, 2:20 am, terry wrote:
On Apr 17, 11:29 pm, Stefan wrote:
Larry Dighera schrieb:
http://en.wikipedia.org/wiki/Mbar
Mbar would be a tad much. You certainly meant mbar.
What does QNH stand for?
Atmospheric Pressure (Q) at Nautical Height (aviation)
Bull****. QNH is *not* an acronym. It's one of over hundred Q-Codes
which were defined in the stone age of radio telephony. The letters were
randomly chosen, think of it as a numeration. Most of those Q-Codes are
forgotten today, but a few still live. In aviation, I mean in aviation
in all coutries except the USA, QNH, QFE and QNH are used to define
different altitude settings (roughly spoken).
QNH stands for the pressure you must tune in the kollmans window to have
the altimeter display the airport elevation when the airplane sits on
the ground. (As opposed to QFE, which ist the pressure to set for the
alitmeter to display zero on the ground and QNE, which is the altitude
which the alitmeter shows on the ground when it is set to standard
atmosphere.)
For those who believe in Wikipedia:http://en.wikipedia.org/wiki/Q-code
I wasnt aware you dont use the QNH term in the States. So what do you
call the number you dial up to make the altimeter read airport
elevation?- Hide quoted text -
That's a good question as Eurocontrol recognises QNH as the correct
local barometric setting (they also state that it means Query: Newlyn
harbour). I thought the ICAO agreed with Eurocontrol on these things?
Cheers
QNH is local barometric pressure reduced to mean sea level.
The local barometric pressure without altitude correction is QFE.
(At least here in the North-East corner of Eurocontrol area)
Tauno Voipio
tauno voipio (at) iki fi
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Altimeter off kevmor Instrument Flight Rules 11 March 26th 07 12:11 PM
Altimeter discrepancy Gene Whitt Instrument Flight Rules 6 August 1st 05 07:11 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Altimeter Disassembly Dick Home Built 3 April 2nd 05 01:27 PM
