"JGalban via AviationKB.com" u32749@uwe wrote in
news:82df7b9654bd5@uwe: Bertie the Bunyip wrote: What happens is that the transition level is localised. they're usually between 3,000 and 5,000 above the local terrain, though that depends on airspace divisions around the area and local state views and traditions. Usually you can expect to transition around 4-5 thou above the airport going up. In mountainous areas, minimu flight levels are dictated by the QNH and temperature. The US is the only country I know of that has a nationwide transition as high as 180. Understood about the flight levels, but how does one set QFE on an altimeter on a high altitude airport? Most altimeters I've seen don't have a sufficient range in the Kollsman window to set anything above 3,000 ft. or so. Ah, right. I see what you mean now. I have a friend who operates for a company that uses QFE and he says you nearly need a crank handle on it for some high alt airfields! I don't know if he has a different sort of altimeter in the 767 he flies, but I ran out of nubers at 1050 when I was in helsinki a while back and it was at 1052. Maybe it's a special order. he was talking about a plce that was about 6,000 feet up. I used to work for a place that used QFE for approach and landing and I found it a major PITA. We never went anywhere over 2,000 feet, though. Bertie |
Looking for TSO Altimeter | Rob Turk | Home Built | 0 | June 9th 07 03:52 PM |
Altimeter off | kevmor | Instrument Flight Rules | 11 | March 26th 07 12:11 PM |
Altimeter discrepancy | Gene Whitt | Instrument Flight Rules | 6 | August 1st 05 07:11 PM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Altimeter Disassembly | Dick | Home Built | 3 | April 2nd 05 01:27 PM |
