Altimeter Question
Old April 18th 08, 07:55 PM posted to rec.aviation.piloting
Stefan
Default Altimeter Question
JGalban via AviationKB.com schrieb:
Understood about the flight levels, but how does one set QFE on an
altimeter on a high altitude airport? Most altimeters I've seen don't have a
sufficient range in the Kollsman window to set anything above 3,000 ft. or so.
If you can't, then you can't, simple as that. If you run out of kollsman
range (be it QFE or QNH on some extreme weather), then ask for the QNE,
that's what it is for.
Old April 18th 08, 08:01 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Stefan wrote in
don't have a sufficient range in the Kollsman window to set anything
kollsman range (be it QFE or QNH on some extreme weather), then ask
for the QNE, that's what it is for.
No, it isn't
Bertie
Old April 19th 08, 04:41 AM posted to rec.aviation.piloting
Travis Marlatte
"Stefan" wrote in message
have a
or so.
I think the question was simpler than that.
The Kollsman setting is not the local atmospheric pressure. You're running
out of Kollsman setting because your just cranking the Kollsman down while
sitting at a low altitude airport.
The Kollsman setting is the calculated value such that your altimeter reads
zero feet at mean sea level. A high altitude airport is going to have a
setting within the same range.
{Totally a United States perspective. Forgive me if you have some completely
different technique for measuring your altitude above the planet}
Travis
Lake N3094P
PWK
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Altimeter off kevmor Instrument Flight Rules 11 March 26th 07 12:11 PM
Altimeter discrepancy Gene Whitt Instrument Flight Rules 6 August 1st 05 07:11 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Altimeter Disassembly Dick Home Built 3 April 2nd 05 01:27 PM
